The speakers have too much bass distortion - Televison & Video
2 Suggested Answers
  • 32 Answers
SOURCE: front speakers in my 2002 Sienna is distorting when bass is 0
ya blew em
Posted on Jun 10, 2009
My jamo d115 speaker tweeter distorts or rattels when any serious bass kicks in, how do you stop this?w
Possible this is a distortion from the Amplifier if the speakers are not damaged. however it is important to switch the speakers to confirm if the fault is relative to the particular channel in which case the amplifier is faulty. If not the speaker can be the culprit. All what is needed is to reduce the BASS level a bit lower when the volume is increased so as to allow the cross over to work. Also if teh cross- over network is faulty within the speaker the bass can vibrate on the tweeter.
Dec 01, 2011 | Jamo Audio Players & Recorders
I installed a Pioneer DEH-P800PRS head unit and 4 Kenwood KFC-1662S speakers in my 2003 Dodge Dakota extended cab truck. I used a Kenwood KAC-5204 2 channel amp connected in parallel. Sounds good at lower...
Hello.... sorry to hear about your problem. Bass is the ultimate evil of coaxial speakers. You have a couple of options here, and this is just my professional opinion because I do not know what your lifestyle details, such as truck space needs, type of music you listen to, budget, etc. If you are looking for alot of bass, the best bet would be to use 2 external amplifiers, 1 for the interior speakers, and 1 for a subwoofer. You would then need to purchase an electronic crossover. With this setup, you can remove all of the low frequencies from the coaxial speakers and put them where they belong, with the sub. You will gain EXCEPTIONAL clarity and a very high volume before distortion level. Again it will depend on what your budget is and if you are willing to compromise on some cab space. The only other option you have at this point is if you are wanting to play your music at high volume levels, you will just need to reduce the bass level as you increase volume. I hope this has helped. Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Pioneer Car Audio & Video
The bass is very distorted and i replaced the battery but still the bass is very distorted and i can not hear the words of any song i listen to. whats wrong with it??
you may have blown a speaker. check the wires behind the speaker to see if there is a short(two or more bare wires that touch)
Mar 10, 2011 | Skull Candy Skullcrushers Headset
I have Mercury 2.1 white speaker.It works fine for half an hour but after that the woofer's sound stops-start frequently at highest bass but when I reduce the bass It works normally with no distortion.
If highest bass means you are boosting the bass for effect then it may be some form of speaker protection cutting in.
The most likely is a Polyswitch, which increases in resistance as it heats up when too much current is going to the speakers. The sound resumes when it has cooled down.
Feb 11, 2011 | Jasco GE 98903 2.1 Speakers
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Center Speaker Audio Very Distorted
Love your screen name.
You didn't say what, if anything, preceded the appearance of the problem. There might be a clue.
Can you describe the distortion? Is it excessively bassy? If so, is it happening on all sources?
I'm assuming this is a modern digital receiver that is capable of many soundfield simulations as well as native Dolby Digital, DTS, multi-channel. If so we can use a stereo source and through simulation redirect some of it to the center speaker.
Using one of your receiver's many multi-channel simulation modes, put in a CD or tune an FM station and use it to diagnose the problem during later steps.
If it's only a single source and that source uses individual analog channel RCA cables, swap in another one or temporarily move the Center Channel feed to one of the other channels to see if it's before the receiver (in the source).or inside the receiver.
For multiple sources:
Is your Center speaker defined properly as Large or Small in the receiver's setup menu?The size refers mostly to the bass-handling capacities of all your speakers rather than their physical size. Speakers designated as 'Small' will not be sent much in the way of bass because they can't handle it well. The LFE/subwoofer channel(s) will get all the bass that was intended for them instead.
If you have a Small speaker improperly defined as Large it may be getting bass that it can't handle and that might sound like distortion. Having a Large speaker defiend as Small would result in less bass than expected but otherwise 'clean' sound.
Check the speaker setup in the menu for excessive volume level relative to the others. There is usually a calibration procedure the receiver will use to help you adjust the subjective voume of each speaker using white noise or tones.
Hope this helps.
Jan 18, 2009 | Sony STR-DE475 Receiver
Just bought a new car. i removed old stereo and put in my kenwood kdc-w808. whenever there is base in a song it distorts i have to turn my base rite down to get rid of it. worked perfectly well in my old...
your speakers probably cant handle the bass.,also they are probably full range speakers ,so hwen the base hits at the same time a voice is singing the woofer is vibrating to produce the basss,there fore distorting the highs and mids {or voice}.You need to add a seperate sub woofer.And puyt capicitossr on the full ranfge speakers to limit the bass..Rating please. :}
Jun 16, 2008 | Kenwood Car Audio & Video
Screeching with Bass
If it's happening only in one speaker, then the speaker is almost certainly damaged.
Mar 12, 2007 | Infinity Reference 6412cf Coaxial Car...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
