Question about Refrigerators
Switching the way a door opens on a WRT15DRA model. The middle hinge's post won't line up on the other side. Do you flip it upside down? It is hard to attach screws if you do
  • 5 Answers
SOURCE: Possesed Phone
you can fix it you self by downloading the update software to fix the glitch. you cam go to motorola.com and get it there
Posted on Oct 18, 2007
catriver
  • 878 Answers
SOURCE: right door handle upside down pinches fingers. how to remove and flip?
mirellis, grab the handle with both hands and push in and up. The handle will slide off the retainer clips. To put them back on, line up the clip holes push in and pull down. I never tried flipping them, but you will find out real fast. This is for the GS6NBEXRL model that was posted, Catriver.
Posted on Dec 01, 2007
ginko
  • 19396 Answers
SOURCE: May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
Posted on Jul 27, 2008
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
timthorne911
  • 464 Answers
SOURCE: UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
Posted on Mar 31, 2009
Hi, I have a hotpoint fridge/freezer future rf 175wp and want to change the doors from right hand to left hand hanging. Do I need to get new hinges? Thanks Dave Horn
Dave,
You should not need new hinges. As long as you have screw holes on both sides you re-use the same hinges, just flip the middle one over. The bottom hinge point, you will need to move the post from one side to the other. Hope this helps!
May 07, 2015 | Hotpoint Refrigerators
Where can i find a bose raidio battery door
Flip the unit upside down with display facing you, take your left hand and put down on the left side of the unit. Look at your thumb near buy or underneath it you will see a triangle with lines running through it thats the battery door for a 9v use the triangle for grip when sliding the door (Opens to the left). You will need 1-9v battery maybe different on newer models mine is a 1st generation model. Good luck, hope this helps.
Mar 02, 2015 | Bose Wave Radio
How to flip a door on hotpoint fzfm171
handle and hinges all removed to opes it side little plugs are in door and ref for this middle hing may bet turned upside down or pin removed to different hole if not handy call a service co. this is not easy all the time make sure all spacer washers are in same place when re installing take pictures as you take apart
Nov 06, 2014 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
One side of oven door hinge won't fit back in when putting door back on after cleaning
when you insert the hinges back into place flip the small lock tab at the hinge pin the locks the hinge for removal
Oct 19, 2017 | Indesit KP9508EXG Dual Fuel (Electric and...
I can't find any instructions on how to reload my one-touch stapler. It shouldn't be hard to put instructions on the internet.
I'm new at FixYa, and I don't own this particular stapler, but I'll give this a shot.
Grip the black (middle) part of the stapler on its sides, flip it over (upside-down) and bend the base so you expose what would be the bottom of the black part of the stapler (now facing up, of course, because the stapler is upside-down). There should be a tab near the hinge that you can simply pull to expose the compartment where the staples are stored.
(That's how I reload my PaperPro stapler.)
Feb 21, 2011 | Staples One Touch Executive Stapler
Driver door has dropped about 1/2". I see a torx
Before attempting to adjust the door, you need to check the wear on the hinge pins. Open the door fully and look at the middle of the hinge. See the pin there? Lift up on the latch side of the door as you watch the hinge pin. If you see the hinge moving around the pin or see the pin shifting back and forth then the metal grommet the pin goes through is worn and needs replacing. Motormite makes a replacement pin set that comes with new grommets ( or bushings to some). It's not so hard to change, but it can be a little tricky. Jack up the door to relieve the pressure on the pin.Start with the top pin. Watch the pin as you jack and keep going until the pin is in the middle of the movement range. Tap the old pin out and then inspect the grommet to see if it's worn past the outer edge of the metal. If it is worn past the edge then you'll need to replace that hinge. Otherwise, you can use that old pin to tap out the old grommet, and replace with the new one, then the new pin. slowly release the pressure on the jack and watch the new pin for excessive movement, then do the bottom pin and grommet.. Test door swing and alignment. If the door still hits low on the catch post, loosen those torq bolts after lifting the door slightly and now lift the door the distance it was low plus 1/8 inch. retighten torq bolts and release jack, then retest the door alignment to the catch post. Don't let the door strike the catch post hard - just let it slowly come into contact as you watch for alignment. Repeat procedure until door lines up centered on taht catch post.
Good luck!!
Nov 07, 2010 | 2001 Dodge Durango
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
How to take apart gateway laptop mt3418
There is no good way to tell you except with a video.
Get a few pieces of Styrofoam to put the screws into. One for the bottom, one for the top, one for misc.
  • Flip the laptop upside down. Remove all the screws, and batteries, doors etc.
  • Flip the laptop right side up and open the screen open completely
  • Remove the power button/hinge panel (snaps off with a screw driver)
  • Unscrew the keyboard 3-5 screws and it removes
Notice how all ribbon cables disconnect.
  • Unscrew the hinges from the bottom portion and disconnect the cables careful to notice the routing.
  • The upper part of of the case separates from the lower using a knife or small screwdriver. Watch remaining screws
That is about it. Put back together asap. Order the parts you need BEFORE you dis-assemble.
Jan 24, 2010 | Gateway Computers & Internet
How do i change which side the door opens
I have a different Bosch but changing the door over is straightforward.
1. Remove the plastic cover above the top door which fits over the controls. There are 2 screws under it holding it on. Lever it up from the back on top and it pops off.
2. Remove the hinge for the top door held on by 2 bolts
3. Take the top door off
4. Remove the central hinge between the doors held on by 2 screws
4. Lift the bottom door off
5. Pull off the bottm plastic cover
6. Move the post in the bottom hinge to the other side. It screws out
7 Replace the bottom door
8 Replace the central hinge on the other side (Take off any plastic caps covering the holes)
9. Unscrew the post on the top hinge (there are 2 possible holes left and right) and put it in the other hole.
10. Put the top door on
11. Bolt the top hinge back on the other side
12 Replace top cover and screws.
13 Move handles (unscrew and pull towards the door edge to get them off)
Jul 10, 2009 | Bosch Classixx KSR32623 Refrigerator
Right door handle upside down pinches fingers. how to remove and flip?
Nov 30, 2007 | Whirlpool GS6NBEXRL Side by Side...
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
