Question about Cell Phones
I have one question, Can i program my phones and use them as a standard alone telephone? without using the KSU Norstar Phone System? i have the M7310 M7208 and M7324 but there is something i can do to use those phone without the system? or i have to use the system for everything? what do you thing?
  • 666 Answers
Nope not possible
Posted on Aug 24, 2010
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
Inactive feature message displayed when we try to access any features on our M7310 phones. This occurred after a power outage.
Dear customer..here is the solution
Sometimes when you put a new (or alternate) voicemail system on a Norstar switch, The feature codes that accessed the old system stay in the KSU memory. If this is the case all of your feature codes will appear inactive even if the voicemail system is operating correctly.
To fix this issue you need to run an External Feature test (XFtest) to identify and remove the leftover codes from your KSU memory. You must have a programming set to access this menu (M7310, M7324, T7316).
Power down the Voicemail unit. Remove connection to voicemail ports from KSU.
1. Press [Feature] **938378 (XFtest). The password will be 266344 (Config).
2. Your display will read Feat code: and you will have options First and Exit.
3. Press First. The first stored feature code will appear, and you will have options Test, Back, and Next.
4. Press Test. Your options will read Remove and OK. Press Remove.
5. Once the feature code is removed, press Next to go to the next code.
6. Do this with all codes until your display reads None Registered
7. Release
Restore connections to the voicemail ports from the KSU. Power the system back up.
The feature codes will be restored to the correct defaults with the completion of the voicemail power-up cycle.
thank u
Jul 09, 2008 | NorStar Lands Phones
Norstar m7310, how to reboot system
Pulling the KSU power cord for 30 secs will reboot it, if that's all you want to do. Not the phone set, the central box. Or do you want to re initialize the entire system? If so you will have to reconfigure everything. Is that what you really want to do?
Mar 20, 2014 | NorStar M7310 Phone
How do I activate a line on a Nortel system to set up a mbox without a telephone extension?
Hi!
All phones that are plugged into the system are automatically assigned an extension. This is a good thing, and it keeps life simple. When you have a specific line assigned to a phone, all it means is that you have the phone programmed to appear and ring on that particular phone set.
In short, find out your extensions number by pressing feature * 0 intercom. That will be the extension that you put in to add the mailbox to that phone.
Now, I am assuming that you are using a voice mail system. If you are not, then you can have your phone service provider set you up with an external voice mail on a particular line.
Let me know if you have more questions.
Jan 06, 2012 | NorStar M7310 Corded Phone
How do I turn on a Norstar M7310 telephone?
The M-7310 is self booting. If it is wired back to the phone system it should start flashing the LED's as soon as you plug it in. The wiring is standard 1 pair of wires on the center 2 pins of the jack. They are proprietary and will only work behind a Norstar telephone system. To see if it is a bad phone, swap it out with a working one at another location. Hope this helps
Bill C. www.dyna-tech.us We also offer remote programming and tech support for the Norstar CICS, MICS and Call Pilot 100/150.
Apr 02, 2010 | NorStar M7310 Corded Phone
How do i get to system programming on my norstar m7310 to get to auto relocate
Enter Administration Mode
  • Using you telephone set push feature * * 266344
  • Display will read Password
  • Using you telephone set enter password: 2 6 6 3 4 4
  • Display will read Configuration
  • Press Show
  • Display will read Trk/Line Data
  • Press Show
  • Display will read Sys speed dial
  • Press Next several times until the display reads Set relocation: Y or N
  • Press Change until the phone displays Y for ON or N for OFF
Jul 02, 2009 | NorStar M7310 Corded Phone
Intercom
Try FEATURE 6 6 and the extension of the phone that you want to page to.
Mar 04, 2009 | NorStar Meridian M7310 Phone
Call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Jan 22, 2009 | NorStar M7310 Phone
Caller ID
First off seven to nine you do not use an external cid unit for norstar systems. Make sure you have a caller id card in the main ksu or key service unit( the phone cabinet) It should say CI on it. If the card says DS then you do not have a caller id card on the system and will need to exchange it for one. Then the system phones will have to be programmed for cid.
Feb 16, 2008 | NorStar Meridian M7310 Phone
Norstar m7310 phone
Rushy: I assume you have a KSU which controls the entire system. The KSU is cabled to each line number provided by your local phone company. Once you have this line established it now makes contact with your phone set via dedicated cabling to each telephone set.. With all this hardware in place you can now program the line keys on each set for either one touch dialing or line access for your dial tone. Program guides can be aquired through GOOGLE by entering " Norstar m7310 program guide".Thank You. Jerry
Feb 08, 2008 | NorStar Meridian M7310 Phone
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
