Question about Monroe Classic Calculator
Monroe 3190 almost the same as Monroe Classic
I have a problem with my Monroe 3190, when I use the distribution column after pressing "enter" it jumps 2 numbers.
Please help me with my problem.
Thank you.
3 Suggested Answers
SOURCE: Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Posted on Apr 22, 2009
  • 5 Answers
Have you remove the tape that used to fix the ribbon cartridge since the time you get the Monroe 7130? If you do remove the tape, please try to take out the Ribbon Cartridge and install it again, by refer to the description of 'Changing the Ribbon Cartridge' in the Instruction Manual. The printer lift may stuck and need to adjust.
Posted on Jan 27, 2010
How do i calculate the standard deviation
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. you should be able to recognize what each variable means.
Oct 26, 2011 | Casio fx-300ES Calculator
How do I use the percentage function on this calculator? Such as subtracting 75% off of an amount
You can use either of this 2 equations.
ex: 75% off of 20
Equation 1: 20 minus (-) 75% = 5
Equation 2: (20*0.75) = 15 then press Ans key
20 - Ans = 5
Hope this helps.
Jun 16, 2011 | Monroe Classic Calculator
I don't know anything about physics or statistics or anything like that so I cannot do a test problem. :-( But I am in physics now and the professor said we needed a calculator that can do 1 and 2 variable...
Do not go buy another calculator because this one does 1-var, 2-var, as well as some regression models, and some distributions.
For 1-var and 2-var statistics read on.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Jan 22, 2011 | Casio FX-115ES Scientific Calculator
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Jun 27, 2010 | Nespresso Aeroccino Automatic Milk Frother
How do you caculate standard form on a casio fx-83es calculator
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
Jun 10, 2010 | Casio fx-300ES Calculator
How to calculate the standard deviaition on the casio fx115es
Apr 05, 2010 | Casio FX-115ES Scientific Calculator
How to do standard deviation
I assume you know the theory. I will only show you the key strokes for 1-Var statistics.
Press the number corresponding to the variable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
Hope it gets you started
Dec 06, 2009 | Casio FX-115ES Scientific Calculator
I CANNOT ADD OR SUBTRACT ON MY MONROE 2125 CALCULATOR, COULD YOU PLEASE SHOW ME HOW TO DO IT?
Maybe you blew a fuse...Does it turn on? Call me at 608-222-2484...Ask for Milt,,will help you over the phone..
Sep 01, 2009 | Monroe Classic Calculator
Monroe Classic Calculator Logo
266 people viewed this question
Top Monroe Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Monroe Office Equipment and Supply Expert? Answer questions, earn points and help others
