Question about Refrigerators
Once my refrigerator reaches the correct temp it cuts off but will not come back on unless I bump it. Lights continue to work so could it be the thermostat?
  • 86 Answers
The t-stat is sticking. You'll need a new one
I hope this helps.
Posted on Aug 24, 2010
Once my dometic av reaches temp Setpoint, it cuts off. Then immediately turns on again, then off again and continues until breaker trips. Is this a thermostat issue or a relay issue?
google it:
  1. Once my dometic av reaches temp Setpoint, it cuts off. Then ...
    www.fixya.com/.../t25789091-once_dometic_av_reaches_temp_setpoint
    1 hour ago - Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric ...
Jul 19, 2015 | Dometic Heating & Cooling
The temp reads 65f. when I change it to 0-33 it goes back to 65f
Thank you for your post, janet!
I understand that your Frigidaire refrigerator is not displaying the correct temperature. Is it cooling? If it is cooling it could be an issue with your control panel or thermostat not registering the appropriate temperature within your refrigerator. I would suggest performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience a display problem or that refrigerator is not cooling I would recommend reaching out to a professional for proper diagnosis and repair. This will help you to avoid purchasing unnecessary parts. I hope this is helpful. -Matt
Nov 06, 2014 | Frigidaire FRS23KF7AB Side by Side...
Shark iron g1462
the lights you witness are correct. once the iron has reached tempreture.
ensure the iron is stored in an upright position between ironing items if left laying down the iron may switch off as an anti-burn or fire safety feature as if left unattended. with the iron placed on its back plate with its point facing upwards the iron should stay on.
I hope this was useful.
May 14, 2014 | Irons
Refrigerator shuts off at correct temp. but does not turn back on
problem thermostat call a technician to properly diagnose and fix
Apr 10, 2017 | Refrigerators
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Heater keeps cutting off as if it reached the set temp.
sounds like its in defrost mode and the electric aux heat is not working
Feb 20, 2009 | EdgeStar Portable Air Conditioner Heater
Heating element not shutting off
thermo. in oven it leads up to the cut off to keep temp correct but sometimes having them fixed is more then a new one in the back of oven take panel off an it will be a copper looking wire covered with a cloth looking sleeve
Oct 11, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Motor never turns itself off
If by motor you mean the compressor itself then no, it should not run all the time. The compressor should run until the thermostat senses the temp. is at where you set it then turns off the compressor. A couple of possible things... if the unit has a leak in the refrigerant then it may run almost continuously since it can barely reach the cold setting you have selected. Or the temp. sensor thermostat may be bad and the unit doesn't know to turn off. There is also a defrost cycle that happens about every 12 hours for a few minutes (depending on make/model on how it works) but that should also turn off the compressor and fans until the defrost cycle is completed. Basically it should turn off when the temp. setpoint is reached or when it's in the defrost cycle.
Jan 14, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
