Question about Hardware & Accessories
I have the intermatic ST101 series timer The lights do not work. The window that tells the time is completely blank. Does this mean I should replace the battery?
  • 395 Answers
Replacing the battery would be a good place to start. They don't last more than 2 years.
Posted on Aug 24, 2010
  • mull47 Aug 24, 2010
    Thank you, Stephen
  • Louise271 Feb 23, 2011
    I have these installed in my 116 unit condos and have had to replace almost 50% at this time. They are only 2 years old!! You can change the battery but it might just be defective like mine are!
How can i set up the time of the pool light in the a box model T10004R?
Typical T1000R series pool control center has space for 2 timers, and comes with one T104M 240Volt timer. Additional timer mechanism can be added to control lights, etc.
Copy following link for setting T104 series Intermatic clock, with link to wiring diagrams.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic pool timers are extremely durable and versatile, and modular so they can be repaired almost indefinitely using ez-to-locate parts
Additional link for replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Oct 28, 2012 | Intermatic T10004R - Pool-Spa Mechanical...
I have an Intermatic ST101 Wall timer switch and I cannot reset it for reprogramming. I hold down the on-off switchand press resetr but it dioesn't clear out old data. when I press on-off switch again...
Open following link for ST01C programming, battery replacement steps.
Timer has 1 year limited warranty against defects in workmanship.
Battery cannot be exposed to low temperatures, or battery life is shortened to 30 days.
http://waterheatertimer.org/ST01C-program.html
Nov 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have an intermatic timer ET170 series and I can't program the days for my lights to come on... I already tried several times but the timer does not take my changes why.
Is this a newly purchased timer?
ET170 series has standard 1 year limited warranty, and is discontinued timer replaced by 7-day, 1 and 2 channel ET1700 series.
The manual shows troubleshoot section:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et175c%20-%20english.ashx
Last step restoration for electronic timers is to replace battery and push in reset button.
Battery compartment is located below buttons.
Compartment slides down and outward and holds AA battery.
If functionality is not restored, then timer has gone bad.
Intermatic customer service:
http://www.intermatic.com/customer%20service.aspx
Aug 25, 2011 | Hardware & Accessories
Timer not working?
Posted under Intermatic T100 series timer:
Open following link for troubleshoot and to identify replacement parts:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
If this is not your timer, then add a comment with model number or description of timer for possible help.
Aug 06, 2011 | Intermatic T104R 208-277Volt 40-amp Timer...
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
After Six years the clock still works fine, just it gets stuck when is is time to turn the trippers on and off
The clock motor has gotten weak.
With Intermatic T100 series timers, replace WG170 120Volt or WG1573 240Volt clock motor for $20.
Upvote the help.
May 24, 2011 | Intermatic T104R 208-277Volt 40-amp Timer...
I am replacing an Intermatic T101 125v time switch dial with a GE 15600 replacement time switch module. The intermatic has posts A 1 2 3 4 and GE has L 1 X 2. How do these map to each other?
GE15600 replacement module snaps into standard Intermatic box.
Timers can be wired different ways. I know all these timers and have them sitting in my office.
I cannot see your timer or your wires, so read information below.
Open following link for clear crossover instructions:
http://waterheatertimer.org/GE-timers-and-manuals.html#GE-replacement
If Intermatic timer has terminals A 1 2 3 4, then that is not traditional T101, but sounds like 120Volt T103.
T103 can be wired many different ways, and is not fully compatible with GE replacement.
If you have wires on all terminals A 1 2 3 4, then add a comment and say what wires you have and what loads you are controlling, for more detailed information.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
For other folks who find this link, it is sometimes less expensive to repair T100 series Intermatic timer with $4 trippers and $20 clock motor.
Upvote the help.
May 16, 2011 | Intermatic T104 24h 208-277v Mechanical...
I have lost plastic pin{red} for my indoor light timer. Is there anything I can use to replace it,or can I buy a new one? If so where can I get them? It is an INTERMATIC TIME ALL Model No. TN111.
Open following link for Intermatic trippers and parts with identifying numbers and ordering information.
According to Intermatic information, TN series uses 107TN222 turquoise ON tripper, 107TN221 red OFF tripper.
Order from Intermatic:
http://store.nexternal.com/intermatic/categories.aspx?Keyword=107TN221+tripper&x=20&y=13
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 03, 2011 | Intermatic Hardware & Accessories
Timer wheel seems to slip. Won't hold time
You posted under Intermatic T104 timer.
If you have different timer, information below may not fit your timer.
Add a comment with correct timer brand and model number.
1) Click manual override on-off to see if Load turns ON, and that override snaps crisp and clean and is not sluggish or hard to move.
If override is not functioning well, then timer is bad. Buy new timer.
2) If dial is rotating, note current time, and watch if dial is keeping correct time over full day.
If dial is running slow, then buy T100 series 240Volt clock motor for T104 timer.
3) If dial is keeping good time, then tripper might be worn and need replacement
Link below shows Intermatic T100 series parts:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any do-it-yourself project.
Jan 06, 2011 | Intermatic T104 24h 208-277v Mechanical...
My Intermatic Timer (model PB115M1) is not keeping time. Without any electrical load it is loosing 3 hours every 24 hours. Its part of an older Intermatic Malibu yard light transformer. Is it fixable or...
...may have solved this one... opened up an Intermatic Model HB31R and it seems to have the WG2030 timer motor... this model (complete timer box) cost $20 or so...
Jun 19, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
160 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
