Question about Refrigerators
My maytag ice2o starting flashing on the digital panel can I reset it
  • 3 Answers
Your high voltage control board went out, very commonproblem. Call maytag and tell them you know this a common problem amd you also know they are replacing the board out of warranty. Worked for me, to which I also asked they overnight the delivery. Simple ten minute fix.
Posted on Sep 01, 2011
Maytag MFI2266AEQ Refrigerator is leaking water from the bottom right side. Why?
Do you have an ice maker, if so turn off the water supply to the fridge and see if the leak stops.
Nov 11, 2016 | Maytag Refrigerators
The ICE2O has gone crazy
Billy, your HV control board has failed. (I know this because I serviced one just last week for the same symptoms and promptly diagnosed and repaired it.) The board can be accessed from the back of the fridge. Roll it out from the wall and look about 2 feet up from the floor on the left hand side. You'll see the cover held in place by 4 1/4" screws. Remove 3 and loosen the last one, rotate the panel out of your way. The board is a snap to remove and replace. The part number you will need is #12920710 and is available at your local appliance parts retailer. It lists for ~$150.00. The kit DOES come with instructions to program it once the repair is complete. Read these completely BEFORE doing the repair so you'll know what to do when you've got it back online.
Aug 13, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
How to reset control panel mdbh979sam1
My Maytag Dishwasher - Will not Start or Complete a Cycle - MDBH979SAM1- the lights keep flashing but will not start.
Jun 22, 2014 | Maytag Dishwashers
I have a Maytag Ice2o that is not staying cold in either the frig. section or the freezer.
hi.because it works for a couple of days.it sounds like u have a problem with 1-defrost timer 2-heater 3-t/stat.good luck.ALI
Jun 29, 2012 | Maytag ICE2O (27 cu ft) Bottom Freezer...
The control lights on the refrigerator keep blinking. No function for water or ice.
Unplug the refrigerator for few minutes, say 30 minutes and then turn it ON. This would reset the control board. If the problem still persists, this is an internal failure, most probably control board.If you have electronics repair experience, could read schematics, would be able to use multimeter and could keep precautions, revert and i would be able to tell you few pointers. However, repairman is recommended as it could be quite dangerous to work on these refrigerators.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2010 | Maytag MFI2568AE Side by Side French Door...
Why is the ice maker and water dispensing panel on my refrigerator flashing? The Ice door at the dispenser is also opening and closing every three seconds. Water and ice are also not dispensing
I called a repair man to fix this problem - "FixYa" was absolutely useless in this case. Turns out there was a short on the control board and it needed to be replaced.
Dec 02, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Rust on the door edge of my SS maytag Ice2O refrigerator?
Your problem is no doubt a bad door gasket which is not sealing. Water vapor from room air is seeping through and condensing on the door edges. A new gasket should be available from your local refigeration supplier, but they are very difficult to replace. Read all instructions carefully before starting, and store your perishables.
Ray
Nov 16, 2008 | Continental Manufacturing Company Value...
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
