Question about Motorola Mobility Moto Q
Keypad on my phone it has locked to the text where u have to enter A1B2C3 and my b and 2 button do not work but the others work not all misc buttons are not working
  • Ken Jones
    Ken Jones May 11, 2010
    What do you want the phone to do? What kind of input do you prefer?
I have the same problem but its with the "b" "c" and "p" buttons. im not sure what is causing this but i deleting all recent prgrams installed. well see how this works out.
Posted on Sep 24, 2008
    Sergeant:
  • 260 Answers
Hi, I think the best solution for you will be to go to Start, Settings, Text Input Settings, check the box if you want Text Prediction to work.
If that does not work then I recommend you reset the phone by removing the battery and wait 60 seconds before putting it back in.
Other things to consider are, make sure you are taking proper care of your battery - the Q requires good strong batteries. You can reset the battery by discharging them completely, then recharging them fully before using them, then repeat.
Also, make sure you have not added programs recently. If you have, you may try removing them. Start Settings, Remove Programs.
If all else fails you may have to try a Master Reset. Start, System Tools, Master Reset. Caution *** a master reset will delete all of your personal information ***
If the phone is still under warranty you should return it for warranty service before doing a master reset.
I hope this helps. :)
Posted on Jun 21, 2008
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
My phone dect 6.0 uniden rings when someone calls but will not dial out
Hello :
Maybe you need to program the phone .
Here I'll tell you how :
  1. Press the Down main navigation button and press Menu/OK. The main navigation button is in the center of the keypad and is cylindrical in shape.
  2. Press either the Up or Down main navigation button until "New Entry" appears on the display.
  3. Press the Menu/OK button and "Enter Name" will appear on the display.
  4. Enter the name using the keypad. Enter the names the same way you would enter text in a text message on a mobile phone. For example, to enter the character "H," press the 4 digit twice. Use the labeling on the buttons to guide you.
  5. Press the Menu/OK button after entering the name and "Enter Number" will appear on the display. Enter the phone number using the keypad.
  6. Press the Up or Down navigation button to select "Save" or "Go Back" and then press Menu/OK. The entry is now programmed. Press the goodbye button; it's the button with the phone icon on a cradle.
  7. Press the Down navigation button and the first alphabetical number is displayed. If you keep holding the button, the phone will scroll through your phone book alphabetically.
  8. Press the button with the phone icon on it (not the goodbye button) to dial the number associated with the phone book entry.
I hope that will help .
rate if useful please !
Feb 22, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do you add a space on the slide phone when texting..i just started to text but not sure where the space button is
On the keypad, press the # sign located on the lower right corner of the phone. This has a LOCK icon and the word SPACE in it. That is the space button when in text mode for your phone.
Oct 31, 2009 | LG CHOCOLATE VX8500 Cellular Phone
My blue ok button on my nokia n95 keypad suddenly not working. Top left hand side above green button.Means i cant text and add contact to send. All other buttons and functions working. How can i fix this?
This could happen often when a phone was accidentally drop or fell or there's is something being installed in the phone system that is being corrupted. To solve this kind of problem is to deep reset all the settings of the phone. It will clear or delete the files inside. Be sure to back-up all the important files in your phone like contacts. To do this just simply dial this number in your phone, *#7370# or *#7780# and it will show a message like "Restore all original settings" and phone will restart. Press okay and then enter this code 12345 which is the default. The phone will restart and reset the phone to the original settings.
Please don't forget to rate this solution..Thanks..:-)
Oct 25, 2009 | Nokia N95 Cellular Phone
My e815 keypad seems dead - power button is the only one working
Well, the phone is done with.
I dont understand why but most "motos"
are like that.
Sorry I couldn't help much...
Jun 26, 2009 | Motorola Mobility E815
Three numbers on my phone keypad not working.
You need to remove the external casing and replace the keypad inside.
The operation can be done while you are waiting at any Phone shop with parts and repair facility.
Apr 08, 2009 | Sony Ericsson K550i Cellular Phone
Htc touch diamiond keypad locked
u can unlock the key lock with long press of call end button like 4 sec see if ti works otherwise
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Mar 17, 2009 | HTC Touch Diamond Smartphone
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
183 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
