Question about Toshiba Satellite 2415-S205 Notebook
Cant charge. got new battery and got new a/c addaptor not charge
My problem is that my computer wont plug into my computer. used to charge started to get looser and looser and not wont charge at all. the place where u plug in the adaptor wont hold in the plug.
help
Apparently this is a common problem on these models. You may need a new AC Socket - you can buy oin ebay, but you have to take the motherboard out to fit it. If you wiggle the plug gently to get it connected it may work. If its jammed up - you might try taking out the bios battery on the motherboard to reset - it worked on mine.
Posted on May 20, 2009
Worked off the battery but it wont charge or run off power cord adaptor
Check and make sure the power adapter doesn't have a fuse somewhere in it. Then chk the wattage output of the adapter. Watts should be marked on the adapter.. Now see what the computer requires. Computer info is on the sticker on underside of computer.To determine how many watts the computer needs, Note the amps the computer draws(on label) and multiply the volts(on computer again) x the amps. Answer will be your needed wattage.
Use only the adapter that came with the computer. They may look alike, but there is a difference. Make sure the computer is powered off. A full charge is needed now since the battery was dead. Allow time and don't use the machine prematurely.
Make sure the adapter output matches or betters the requirements of the computer.- Good Luck-Ned
Jul 23, 2014 | Barco R9852000 LC40 Compact PC (R98 52000,...
I cant charge my e 705 ereader
What are you using to charge it? How old is your ereader?
Are you using a usb cable to computer to charge? Or do you have an adapter that goes in the wall socket that connects to your usb cable.
You may need a new usb cable, or depending on the age of your ereader maybe a new battery.
Oct 26, 2012 | Sony e-Book Reader
It wont charge the battery, it says its using AC power. I cant use it unless its plugged in..
If the computer is telling you that it is plugged in but the battery won't hold a charge the most likely explanation is that your battery is either spent (if it is older than two years) or it is defective (if it is a new battery).
Mar 14, 2011 | HP Mini 1000 Netbook
Disney MixMax player... JUST bought this device. I installed the software CD, but that is JUST for the online/media storage component... I plugged it into the computer & computer wont recognize it at...
The manual indicates that it should show charging as soon as connected, and takes three hours to charge.
I have found that on some devices, this does not happen, and it takes a few minutes for the device to get enough charge into the battery to start up. This especially from new, or if left for a long while.
Try giving it a long charge, six hours is recommended by some manufacturers, using the same type of battery.
leave your computer on, it won't hurt it, as the USB ports, only supply power when it's on.
If it does not work then, as you have only just bought it, take it back.
Feb 07, 2011 | Disney Mix Max Plus DS19025 Digital Media...
My camera battery ran out and when i plug it in to charge it with the original charger nothing happens at all, cant switch it on and it doesnt charge, it wont do off the computer either, i tried it with a...
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
May 27, 2010 | Kodak EasyShare M863 Digital Camera
Power problems with a Compaq Presario C700
Sounds to me like a broken connector on the socket on the motherboard.check, ,or a broken wire at the plug end, check, or the like, or the battery is not making contact as you discovered. Meter the PSU, and wiggle the plug, and socket and see if it makes and breaks connections.
Mar 07, 2010 | HP Compaq Presario C700T
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
Toshiba Satellite 2415-S205 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
