Question about Samsung RS2556 Side by Side Refrigerator
Fans in refrigerator side are not working thus cooling is not functioning adequately.
    Problem Solver:
  • 8 Answers
How you know that
Posted on Aug 29, 2010
Not cooling
condenser must be burnt
Jan 19, 2012 | Kenmore Side by Side Refrigerator
Frsu201ai side by side , freezer is freezing ,but the refrigerator is not getting cold and both fans are working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Daewoo Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have a whirlpool side by side (GD5LHG) that quit cooling and freezing. both fans are working. is it the compressor?
A refrigerator not cold enough is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix.
1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it.
2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning.
3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the freezer. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost.
4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C.
5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted.
6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply.
7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light.
8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
Good luck....
Aug 08, 2010 | Whirlpool GS6NBEXR Side by Side...
Freezer is not working and mass amount of water leaking frombelow
That is probably the compressor. There should be a fan close by. When the compressor runs, does this fan turn? The fan must work properly for the entire refrigerator to cool adequately. The purpose of the fan is to pull cool room air over the coils and remove heat. If this heat is not transferred to the outside of the refrigerator, the cooling cycle will not function properly.
If the fan is not turning, it will need to be replaced. These are readily available.
Oct 12, 2009 | Maytag MSD2650HES Stainless Steel Side by...
MY FREEZE DOES NOT FREEZ BUT IS COOLD DOES IT NEEDS GAS
When the compressor is running, two fans should be running. One inside the freezer compartment that moves air over the evaporator coils. The other is under/behind the fridge that cools the condenser coils.
If the fan on the condenser coil (the one under/behind the fridge) stops working, the system cannot dissipate the heat from those coils, and thus cannot sufficiently cool the inside of either the freezer nor fresh food compartment.
On mine, when the condenser fan failed, I noticed right away. The front face of the wall separating the compartments became very hot. Extremely hot.
Apparently the refrigeration system is designed so that waste heat keeps condensation from forming where the magnetic gaskets on the door need to seal. When the condenser fan failed, there was too much waste heat (because no heat was being dissipated from the condenser coils by the fan), thus making that gasket-sealing area very hot.
If it is your condenser coil fan, you can relieve the problem temporarily by removing the bottom back panel from the fridge and aiming a box fan (a regular room or window fan) at the condenser coils. This will circulate air over the coils, thus removing heat from the coils.
Jul 29, 2009 | GE GSH25JFR Side by Side Refrigerator
Samsung RS2556 Side by Side Refrigerator Logo
67 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
