Question about Vacuums
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesnt suck stuff up anymore.
  • Iz2urFalt Aug 27, 2008
    I have a Bissell 1425 little green turbo machine it wont suck the turbo brush does not turn and it blows air out the back with no suction at all.
  • Anonymous Mar 14, 2014
    doesn't **** up debri dirt blows out the back of vacuum
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=571660
Generic problem for all Vacuums
Posted by katweaver3 on May 04, 2008
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesn’t **** stuff up anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Normally if your vacuum has a round belt you may have your belt on backwards, please reverse the belt and the suction will return also you may have a clog in the tube leading up to the bag or dirt cup would be anther reason for the blowing instead of suction. This is not covered under the factory warranty. Feel free to contact your local vacuum dealer for questions.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on May 05, 2008
Dirt Devil bagless upright. sucks up dirt in the front and spits it out in the back. I have taken it apart to check for visible clogs in hoses and checked belt and rollers all of which are fine. what next?
There seems to be no vacuum drawing the debris away from the brush head. Remove the debris canister to check for air blowing into it. Check particularly, the area where the brush head pivots off of the upright portion. Hope this helps!
Jul 26, 2010 | Dirt Devil M110000 Bagless Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Our dirt devil vacuum is blowing out air instead of pulling in air.
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Dirt Devil vacuum sucks... figuratively
Well, I guess your visitors have come and gone, but the vacuum remains the same. It sounds like you have a broken or worn belt. The belt should be changed once a year (approx) and can break if something is picked up that jams the brush. It is also possible that you have something obstructing the vacuum inlet at the brush housing.
If the belt is worn, it can still look o.k., but won't have the tension to turn the roller when it engages the carpet. I suspect the belt is your trouble.
Mar 21, 2008 | Vacuums
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
1,041 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
