Question about Canon PIXMA iP1600 Printer
How do you fix a paper feed problem in a Cannon iP1600
  • 472 Answers
  1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
  2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
  3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
  4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
  5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
Good Luck!
Posted on Aug 24, 2010
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
How to fix paper alignment
There is not enough information to really answer the question. However, if the paper is not "feeding" check for jams of other paper inside the printer.
The "FEEDER" part where you put the paper in usually has "SLIDEABLE" guides to keep the paper feeding correctly
May 03, 2014 | Canon PIXMA Office Equipment & Supplies
Paper Feed problems for Cannon MP600
Mechanism Problem replace the mechanism with new one.
Jan 01, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Canon ip1600 jams paper when operated.why?.
You got a small shred of paper stuck in the paper track somewhere.
You could try feeding a sheet of light card or heavy gauge paper through which may clear it for you if that doesn't work you're going to have to get into it a check out all the rollers, right up to the edges, of the paper track. Don't forget to disconnect from the power source before you take any covers off.
Apr 22, 2010 | Canon PIXMA iP1600 Printer
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Cannon ip1600 is not working. It appears to be in good shape but it is flashing 1 green then 5 orange. I just reinstalled the driver.
this will happen when the paper is jam or any dust is there. so first check if there any dust or paper. other problem is the cartige \ toner  problem so pick out the toner or cartige then reinstall . i hope that you printer will work.
May 09, 2009 | Canon PIXMA iP1600 Printer
Cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Canon PIXMA iP1600 Printer
My cannon pixma ip1600 has a paper feeding problem. It can't feed the paper to print. help please.
'Paper jam msg' when there's nothing stuck in there...???
Sorry can't help. Maybe you have damaged one of the paper jam sensors?
Try the link below which is the manual
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 29, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
234 people viewed this question
old marine
old marine
