Question about NexxTech N500D 5-Disc
Nexxtech n500d tray will not open. Power is on; possibly disc is lodged. Cannot find owners manual. Have not taken shell off unit as of yet. Is there a way to open the tray manually?
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: nexxtech n2000 The manual says CD-R with "Digital"
I'm pretty sure it actually says something to the effect of "These discs are marked with "Digital Audio" and the logos shown below...', the operative word being AUDIO.
DATA discs do not work on a consumer CDRecorder.
Posted on Jul 09, 2011
mastermaid
  • 502 Answers
I found the Nexxtech N2000 manual here
Posted on Oct 31, 2012
brighton_mik
  • 99 Answers
David Dunn is correct "DATA discs do not work on a consumer CDRecorder" AUDIO recordable disks are required!
Regards
Posted on Jan 08, 2015
The power comes on; however, nothing happens. We took the cover off and nothing happens. We hit :"open/close" and nothing happens, no spinning sounds, nothing. What can be wrong? Where can we...
Looks like the motor is Shot, Don,t evan waste your time to take it in to get repaired, It will cost you more, then to just get a different one, I have got good use ones for friends of mine for $7. to $30, at the most,
Nov 10, 2012 | NexxTech N500D 5-Disc
Disc tray cannot be opened
Hi, The unit is in initialization/reset mode immediately after powerup. It does a self diagnostic sequence. When a fault is detected, it actually locks up till the fault is removed/repaired. A couple of things you can do: 1. Unplug the unit from the mains for a couple of hours; 2. Check your manual if there is a hard/full reset sequence/button and perform it; 3. Remove the topcover and inspect the loading tray. There is a possibility that a CD is stuck, lodged or skewed inside; 4. There is also a possibility that the loading mechanism is stuck, defective belt/gear; 5. if the unit is still under warranty, require service or replacement; or 6. if no longer under warranty, seek the services of a qualified professional. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | iLO DVDRH04 DVD Recorder
Hi,the door for putting disc in wont open.every time i push the button there is noise comn from machine like its trying to open but it cant?
This happens to me every now and then.
Here is how you can get around it:
Sometimes, you cannot open the disc tray on your Xbox 360 console by pressing the eject button. Any of the following things may cause this problem:
  • There is a hardware failure that affects the console, the disk drive, or the eject button.
  • A disc is lodged in the mechanism.
  • The clear protective plastic strip that is applied to the front of the tray to protect it during shipping is preventing the disc tray from opening.
To manually eject the disc from the disc tray, follow these steps:
  1. Unplug the power cord from your Xbox console. For more information about how to disconnect the power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect your Xbox 360 power supply
  2. Position your Xbox 360 console horizontally, as you would position a VCR or a stereo component.
  3. Remove the faceplate from your Xbox console. For more information about how to remove the console faceplate, click the following article number to view the article in the Microsoft Knowledge Base: 907331 (http://support.microsoft.com/kb/907331/ ) How to attach or remove the faceplate on your Xbox 360 console
  4. Depending on the kind of disk drive that you have in your Xbox 360 console, you can use one of the following methods. Note In each case, make sure that you align the tool (a paper clip or stiff wire) to pass through another notch behind the hole on the console casing. Collapse this imageExpand this image906935.jpg
    • Method A: Insert a straightened paper clip or other small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paper clip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method B: Insert a straightened paper clip or other small, stiff wire into the second hole from the left side of the disc tray. Push the paper clip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about 1.5 inches (approximately 4 centimeters) from the left edge of the disc tray.
    • Method C: Insert a straightened paper clip or other small, stiff wire into the hole that is directly under the "X3" logo on the Xbox 360 label on the disc tray to release the disc tray. The hole is located about 1 inch from the right edge of the disc tray.
  5. After you release the disc tray, the tray pops out slightly. You can pull the tray out the rest of the way to remove the disc. Note If you use method A or Method C in step 4, you may have to firmly press the disc eject mechanism to eject the disc tray.
  6. If you determine that a hardware failure has occurred that affects your Xbox console, contact Xbox Customer Support or submit a repair request for your Xbox 360 console.
(Information taken from: http://support.microsoft.com/kb/906935)
Hope it helped.
Nov 16, 2009 | Microsoft Xbox Console
Only one dosc will play.
TRY TAKIN THE TOP OFF AND BLOWIN IT OUT WITH A AIR HOSE
Jun 16, 2008 | NexxTech N500D 5-Disc
Locked dvd tray.
Press stop and eject buttons on player for 6 seconds, display will show unlock message and job is done.
Mar 08, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Tray won't open
It could be electrical or mechanical. Without checking there is no way to be sure. You can get the service manual for your model for 10.00 at the following link. That should get the problem taken care off.
http://www.electronicsrepair.net/dvd9.shtml
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Dvd tray do not open
Someone on this site suggested a fix for a different player.  Open up the unit to get to the dvd changer.  If the disk are not aligned, then push them so they are even.  It may take a while to see where they are but it worked for me.
Jan 14, 2008 | NexxTech ESDVD100 System
U99 code and tray won't open
Thats a reset code # its on page67 of your owners manual. Unplug the unit for a bit(5minutes) plug in turn on the power then turn off again then back on. If this dosent clear the code, contact panasonic at 800-211-PANA Good luck
May 09, 2006 | Panasonic DMR-ES30 DVD Recorder/VCR
NexxTech N500D 5-Disc Logo
Top NexxTech Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
