Question about Nokia N95 Cellular Phone
The screen is completely black when in closed position, OK when open. Just happened this morning. otherwise fine.
    Genius:
  • 1,478 Answers
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Posted on Aug 24, 2010
Why does screen only work certain places
This is a common problem with laptops in general, I know because I have fixed this problem in quite few. What happens is that every time you open and close the lid you bend the wires from the monitor to the mother board. Over time like any wire that is bent back and for will eventually break. The reason it works in some positions is because the insulation around the wire holds it close together and in certain positions the wire connects. Unfortunately since there is something like 21 wires finding the broken one can be difficult because the insulation will be intact. I generally just buy from ebay a new monitor cable that suits the laptop and then the fun begins. Dismantling the laptop, If your game try it otherwise give it to someone that knows how to do it. Good luck.
Sep 10, 2014 | HP Pavilion Chromebook Black Laptop...
LGR7647 will dry fine but smells like gass only when it runs.
make sure the air shutter on the gas nozzle isnt completely blocked or changed positions as the flame needs oxygen to make combustion complete otherwise the gas wont burn completely and you will get a black smoke that smells like raw gas
Dec 06, 2012 | Dryers
Top left corner of screen completly black everything else is fine. Please help determining problem?
hi,
i think ur tvs closed caption option is ON. make it of by the following procedure .
1.press menu and select setup
2. in the setup menu select cc.
3.in the cc menu select mode and change it to off.
4. then press ok. exit menu and and watch the corner.
if nothing happened ,
do the above mensioned first two setup and
3. in the cc menu select cc reset and then press ok
ok,
Dec 15, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Loose Monitor on a HP Pavilion ZV6233nr Laptop
It seems that some screw that was loose is now totally out of socket. The latch assembly might be disbalanced due to that. To me it doesn't seem to be a broken latch.
Apr 04, 2010 | HP Pavilion zv6233NR Notebook
Whilst in use, the screen turned red, and is now blank
same happened try the towel trick otherwise ull have to send it off
Dec 14, 2009 | Microsoft Xbox 360 Elite Console - Black
Garage door close but motor keeps running
The close setting limit switch needs adjusted. Once it is adjusted it should work just fine.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Black screen. Nothing happens. It was working fine this morning. Took it out to play it after work. Nothing. The screen is black.
Does the zune software or Windows recognize the device? if so, you may need to update it, or re-set it.
the zune software and website will have information on how to do this. Hopefully the problem can be solved with an update rather than a complete re-setting of the device.
Oct 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
Black screen
you restore the pc back when it was working fine,you can do in safe mode
May 30, 2008 | Dell Inspiron 1501 Notebook
Avhp-6600
i have the same problem with my unit. there is a way to reset the screen so it starts to come out again as i have done it 3 times before. i forgot the exact method but it involves the "rear" "band" and "reset" buttons. i found this out through calling pioneer canada tech support and i will call them again on monday when they open.
May 15, 2008 | Pioneer AVH-P6600DVD Car DVD Player
Nokia N95 Cellular Phone Logo
20 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
