Question about Kenmore 53542 / 53544 Side by Side Refrigerator
ICE MAKER DONT MAKE ANY ICE - Kenmore 53542 / 53544 Side by Side Refrigerator
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
Ice maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 13, 2010 | KitchenAid KTLA19EMSS Stainless Steel Top...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
ICEMAKER dosn't work50221000
You can check to see if you have water going to the water valve (occasionally they will get plugged up at the tapper water shut off). If you do have water then you need to put 120v to the water valve. You are going to have two valves. One is for drinking and the other is for the ice maker. there are two plugs, one for each valve. Switch them. then push the water dispenser for ten seconds. No water will come out but water should come out of the ice maker. Check the ice maker to see if you have water. If you do then replace the ice maker. If you dont replace the water valve. Dont forget to put the plugs back the way you found them.
Mar 21, 2010 | Kenmore 25.4 cu. ft. Side-By-Side...
Ice maker not working but water keeps leaking and freezing on the freezer door
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards
Jan 04, 2010 | GE GSS23SGSSS Stainless Steel Side by Side...
Fridg wont run with the ice maker attached to the unit, we dont really need the ice machine do we need to keep it attached.
You can remove the ice maker unless it is the older model that has the defrost timer in the head of the ice maker. Please get me a model# so I can look this up for you.
Thanks
Vic
Jun 27, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The ice maker works, I poored water directly to the ice maker and it works, don't understand what you mean with alligator clips, should i just take the hose leading to ice maker off, the intake water valve...
Wrong! ok what it is you have a double water valve. 1 valve goes to the ice maker and one goes to the water dispensor. what you need to do is take the valve that goes to the ice maker by tracing the water line from ice maker to the valve and jump it direct with 110 volts. if you get water by doing that the ice maker is bad if you dont get no water that way it will be the water valve
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator with ice maker but no hook up
just make sure the lever on the ice maker is up and locked or the switch on the ice maker is off ( i dont know what model you have) but thats all you need to do , if at any thinr it gets turned on dont worry it not a problem it will just cost you a little nore to run . no damage to the fridge or ice maker .. please rate this answer , i am new here and it will be a great help thanks and good luck with your fridge
Jan 16, 2009 | Maytag Refrigerators
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
