Question about Excalibur RS-310-EDP Remote Start Keyless Entry Dlx Map:58.50
How do i turn up the sensitivity on my alarm?
    New Friend:
  • 103 Answers
You will need to find the IMPACT sensor and use the dial on it to adjust the sensitivity.
Posted on Aug 24, 2010
Alarm goes off when unlocked and undisturbed why?
Jeff, maybe sensitivity can be adjusted, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Adjust Car Alarm eHow
2008 Toyota Tacoma Alarm too sensitive
Thread How to adjust the sensitivity of car alarm
http://www.driveaccord.net/forums/51-8th-generation/60017-oem-alarm-sensitivity-setting.html
Mar 23, 2016 | Cars & Trucks
MY CAR ALARM KEEPS GOING OFF FOR NO REASON
Your car alarm has a sensitivity setting if the sensitivity is too high it will set off the alarm if the wind blows too hard or a heavy vehicle drives by in close proximity turning down the sensitivity will solve this problem
Nov 18, 2015 | Cars & Trucks
My alarm has just started going off....
On the left lower side of the drivers compartment by your left knee and the parking brake/ hood release you should see a little knob that controls how sensitive the car alarm is. If you turn it clockwise (right) it makes it more sensitive to the left (counter clockwise) less sensitive.Make it less sensitive so it won't cry. Hope this helps.
May 28, 2014 | 2001 Jaguar S-Type
2001 mercury cougar 2door coupe, how do I stop an unexpected alarm?
If it is an aftermarket alarm then you adjust the sensitivity it under the dash youll see a little square box turn to the right and you decrease sensitivity or left to increase lets say a feather fall on it and the alwrm goes off. Now if it is factory alarm they have the access for it and they reprogram the alarm sensitivity.
Apr 24, 2011 | 2001 Mercury Cougar
Can the sensitivity for the alarm system be adjusted
no, there are no adjustments.. if the alarm has an issue then a code should be stored. You will need to retreive it to begin with.
Jun 11, 2010 | 1999 Oldsmobile Alero
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
The alarm go off for no reason and does not stop when i turn key in door whats best way to solve where would i find alarm horn
you should have a sensitivity box under the dash on your drivers side turn the sensitivity level up higher
Jul 05, 2009 | 1995 Ford Escort
Make car alarm more sensitive
Locate the shock sensor. Using a small screwdriver you can adjust the sensitivity of the sensor. Move srew in only 1/4 turns as this will make big adjustments. Adjustments may make alarm too sensitive so try it out and see what works for you.
Apr 04, 2009 | Vehicle Parts & Accessories
Van Alarm keeps going off during the night, for no reason!
yes, the sensitivity can be adjusted. is it a factory alarm or did you have it put in? Ford's have a tendency to cross wiring causing alarm to go off every hr or every 2hrs it will be consistent. next time time it.
Mar 17, 2009 | Code-Alarm Code Alarm Transponder
Car alarm
The shock sensor needs to be adjusted. Its too sensitive. There is small box mounted next to the alarm(brain/box) it has a small flat head screw on it, turn clockwise to increase sensitivity and counter clockwise to decrease. Good Luck
Dec 18, 2008 | 1995 Toyota Corolla
Excalibur RS-310-EDP Remote Start Keyless Entry Dlx Map:58.50 Logo
222 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
