Question about Haier BC112G Wine Cooler
Stopped cooling compressor warm to touch - Haier BC112G Wine Cooler
  • 86 Answers
Feel the condenser on the side to if its warm top to bottom. If It's warm good if it's cool bad it's out of gas. That means leak in the system. If there is a leak, a new box may be cheaper than to fix it. If it is warm check the evaporator and evaporator fan. Make sure the fan is working and the evap-coil is not frozen.
I hope this helps.
Posted on Aug 24, 2010
  • Scott Petersen Jun 04, 2013
    Is there an evaporator fan on this unit? After removing the evaporator and checking the parts list, I don't see an evaporator fan to purchase.
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
COMPRESSOR WARM TO TOUCH ,OVERLOAD RELAY CLICK WHEN PLUGGING INTO THE OUTLET
Compressor faulty, most probavly. let it cool altogether and try to restart. If it has a start capacitor, replace that first in case it is that simple. If the relay and capacitor are ok it is time to replace the compressor.
May 16, 2012 | Refrigerators
Very hot to touch compressor, is it safe?
Compressors do usually get a bit warm during operation, but unless you left the door open for an extended period, or cooled warm foods in your freezer, the compressor would periodically run, then stop and cool off. If you observe your refrigerator for a while and notice that it is running much more than usual, it may to be serviced, possibly to look for a coolant leak or other similar issue.
May 17, 2011 | Frigidaire Freezers
Both refrigerator and freezer have stopped cooling. The compressor sounds like it is working and then will stop. The fan is working. The copper pipes coming from the compressor are hot/warm to the...
This sounds like your refrigeration unit is low on charge...there probably is a leak in the system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 25, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
First gathered water at the bottom, thought that is was due to something touching the back. Stopped fridge, cleaned it, started it again. Light on but no familiar noice of the engine starting again. Engine...
Don't know the model/brand off the top of my head...
But: If the compressor is warm/hot, but nothing is happening, I ask this:
Even if the fridge is not cooling, is the compressor running, or dead silent?
If silent, but warm, do you hear a "Click" every so often ? Maybe 3 to 5 minutes apart, followed shortly by a 2nd click ?
If so, most likely the compressor has seized, and this is the over-current trip acting (thermal, so it needs time to cool).
Big problem if it is the compressor (expensive).
The only other thing that might cause a similar occurrence, would be if the compressor has a Start capacitor. If this has died, the compressor will not turn - just sit there getting warmer, as the over-current trip acts.
If it was a dead thermostat, the compressor wouldn't get power, and would be cold.
Dec 12, 2009 | Smeg Refrigerators
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Fridge/Freezer working sometimes. Starts and stops
Need you to check the compressor to see if too hot to touch. If so unplug and don't leave it plugged in until we find the problem. This could be start capacitor, start relay, overload or a bad condenser or evaporator fan motor. Like to know he model number to help you better, Let me know, Sea Breeze
Jul 21, 2009 | Refrigerators
Cools at start up....then gets warm..compressor is warm.
I would need to know the model of this. However if the condenser fan is Not runing then the problem is that. If it is then it could be the sealed system and you will need a tech to check it out.
Apr 10, 2009 | U-Line 15R Compact Refrigerator
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Haier BC112G Wine Cooler Logo
151 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Haier Furniture Expert? Answer questions, earn points and help others
