Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch dlx series SHU 3300
I have a Bosch DLX Series, SHU3300 and the water will not go into the dishwasher.  I have taken off the kick plate, but it is almost impossible to see anything.  I took out a small amount of water by using a towel and pushing it into an area that was a bit wet. So frustrating because we are rural and it would cost about $200.00 at least to have a repair person - I didn't see any leaks and I also noticed I would need a HEX screwdriver, do you recommend taking more than the kick-plate off to further investigate?  Where exactly is the float plate located?  Thanks!
  • 2 more comments
  • Anonymous Aug 04, 2008
    Equipment: Bosch SHU 3300 DLX series
    Procedure: Dishwasher starts normally, Lights indicate cycle, Motor/pump sounds normal
    Problem: There is no water
    Checked: Water supply, debri filters and electronics
    Next?
    Is the motor/pump something that I can get to reasonably, or does is require complete removal and disassembly?
  • cjbravo2044 Aug 14, 2008
    My bosch dishwasher is not filling with water. I cleaned the drain tray it had some plastic in it, I cleaned it out. The lights are.
  • shadownto Nov 08, 2008
    Our Bosch dishwasher isn't filling OR draining. The motor is still running even when switched to "reset" and if I open the door the motor still runs. We've cleaned out every filter we know about, taken a few bits off, etc. Not sure what the model number is, but it's a Bosch classixx.
  • Anonymous Mar 25, 2014
    Bosch si1506b -
    Our dishwasher is leaking and appears to have a puncture on the bottom plate, so is leaking water when we use it. Not heaps, but enough to notice. Is the bottom plate repairable on this model ?
    many thanks,
I do not see where the problem is identified. Is it a float switch or water pump ??
Posted on Nov 06, 2008
You need to remove the outside of the door to give you more room remove the six torx screws on the inside of the door sides only do not remove the top ones then the out side of the door will come off on give you room to work on it
Posted on May 08, 2008
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Bosch vision 300/500 dlx series washing machine: how do you remove the front kick plate to access the pump?
Bosch vision 300/500 dlx series This video will show you how to change the pump washing machine Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 08, 2012 | Bosch Washing Machines
My bosch dlx series dishwasher acts as if it is getting no power at all. Have tried the circuit breaker. No luck.
Hi Kristen,
Welcome to Fixya.
Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
The end result is no power to the controls. Check it out and post back what you find.
Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you.
Good luck.
Regards,
Macmarkus :)
Sep 22, 2010 | Bosch Dishwashers
Our Bosch DLX series dishwasher slowly fills up when it isn't running. If we don't use it for a day or two the water will flow out the bottom. When it runs, it runs normally.
Hi, the problem is the water valve itself. Based on your description and the fact that this is a common issue with Bosch dishwasher's a new valve will resolve the problem. You'll need a new valve assembly part # 425458 and it's available at most part's places or online. It is about $25 - $30. Let me know if I can assist you further. Thanks for using "fixya" for your inquiry. Please take a second and rate the info provided for you here. Good luck. Macmarkus :)
Mar 21, 2010 | Bosch SHU9915UC Dishwasher
Leaves a scum on the dishes
Sounds like your water temp is too low,there is a heating element in the bottom that heats the water that is circulated,if it goes out it wont get hot enough to dissolve the soap,or clean your dishes.its not to difficult to replace.
Hope this helped.Let me know by rating me, or
For more help go to live chat.
lenwest
Jan 30, 2009 | Bosch Nexxt DLX WFMC4301UC
Bosch DLX series didn't drain, now no power
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Sep 01, 2008 | Dishwashers
Bosch wont
Faulty inlet valve or water in the bottom tray which will activate the float swich and pump out any water. See that this moves up and down freely. Turn electrics off first.
Jun 18, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
1,131 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
