Question about Minolta Cameras
I have an old model Minolta AF 35-80mm lens with a permanently installed front lens cover that broke years ago in the open position. Is it possible to remove or replace these? I use this lens on a Sony camera and am hoping to fix it.
SOURCE: lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Posted on Dec 19, 2007
  • 135 Answers
SOURCE: Sony Digital SLR
You should have no problem, if they are maxuum af. The others should work too- I have an Alpha 100. The alpha 100 works great. I used to run my own photography business, and searched around for quite a while before I found the alpha. There is an adapter ring that i bought, that makes it possible for me to use my favorite old pentax screw mount 135mm f1.6, or any other screw mount, on my alpha 100.
The only drawback I found was you cannot use any other flash(at this time) than the onboard one-or the sony only flashes-which are a little pricey. Different size hot shoe is the reason. I haven't found an adapter yet-but I'm sure someone will make one. The alpha doen't have a real time display- or asa of 3200. I'm hopeing for a firmware update/upgrade to correct this. BUT the newer models with a higher than a100 number do have realtime lcd, and do go to asa3200. And they use either sony mem.stick or CF cards happy shooting
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Posted on Aug 27, 2008
t00nz
  • 4738 Answers
SOURCE: kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 05, 2009
  • 11967 Answers
SOURCE: Konica Minolta DIMAGE G600 getting System error S 0042 message
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 20, 2010
CL) U) 28-300/3.8-6.3 AF MINOLTA what camera will this fit
Sony bought out Minolta and a lot of the old type Minolta lenses will fit on Sony cameras but not all of them.
Jul 08, 2014 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Purchased an eos50e with tamron lens 28-200mm a few years ago, can the lens be used with a digital camera
its not possible to use the lens with digital camera .........but can you be more specific about the digital camera with which you are trying to use the lens
Aug 07, 2008 | Canon Cameras
I have an older Minolta 50mm AF lens that sticks wide open. If I tap the side of the lens, it will shut, but my Sony a550 cannot control it. What can I do to fix it? The camera runs my other two lenses...
Having been there with an older Minolta lens, I'd guess the lubrication on the iris has thickened to the point that the leaves are sticking open (normal position except during time when shutter is open). Time to find a local Minolta/Sony authorized repair shop and have it cleaned and lubricated.
Oct 09, 2010 | Minolta Cameras
Quantaray 70 - 300mm for Minolta AF (25-166-4546)
Check you manual, but it should be no problem- Sony bought Konica Minolta to have the Minolta lens mount (and engineers). Your old lens doesn't have all the internal electronics (and connections) of the new lenses, but every old minolta AF lens i've tried works fine with alpha
May 02, 2010 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Auto focus not working properly.
Hi It sounds as if the scale ring has gone ie needs a new one are you uk
Feb 27, 2009 | Sigma AF 28-200 Lens
How to get the lens apart to clear bits on the front element
The front element is easy to remove.
There's a plastic cover on the front of the lens which has a very small hole in it.
Get something like a very small screwdriver in that hole and prize the cover off.
Remove the 3 screws in the next plastic cover and remove it.
The next 3 screws you see hold the front lens element on.
This whole part rotates to adjust the infinity focus and is kept in position by those 3 screws.
Make sure you mark the position by maybe making a small scratch in the plastic next to one of the screws.
Or maybe scratch around one of the screws.
With those 3 screws removed the front element with the lens just falls out.
Aug 27, 2008 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Minolta 7000 SLR
The Konica-Minolta 5d, and 7d, both discontinued but available used on ebay and other places will work with your AF lenses, as well as all the sony alpha camera bodies. KM sold their camera business to sony, and most of the whole maxuum/alpha/dynax group of engineers went with the sale to Sony. I had a 7000, and an 8000i, and all my lenses are quite happy on the 7D I picked up a few months ago on ebay.
Mar 27, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Sony A100 compatibility
It would help if you actually gave details of the lens!
All the old Minolta AF and MF lenses will fit the Sony A100, but only the AF are auto-focus compatible.
Since the Maxxum 7000 was an AF camera, I would image that that is an AF lens pictured on the front.
Check out this site for more details:
http://www.mhohner.de/sony-minolta/lenses.php
Matt
Feb 29, 2008 | Sony Alpha DSLR-A100 Digital Camera
Minolta Maxxum 7000 35mm SLR Camera not working
Dear Minolta friends,
I have recently bought a second hand Maxxum 7000 and a AF lens, but found the body not ocntrolling the aperture while shooting. I know 7000 has someting special. Is my problem is due to lens and body compatibility or actually the malfunction of the body. I am sure the AF lens is ok since i have tried it working with another minolta af body.
Can give me an advice?
Aug 02, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Cameras Logo
15 people viewed this question
Top Minolta Cameras Experts
Tony Parsons
Tony Parsons
David Payne
David Payne
Are you a Minolta Camera Expert? Answer questions, earn points and help others
