Auto convergence won't won't rca model R52WH74
This tv needs good power make sure you do not have a bad breaker that is arcing or loose connections in the walls a recepticals line noise will affect the TV so check for clean power Also check the voltage coming in your house if it is below 116 volts call electric company...I had that problem my voltage was 103 and the convergence went out all the time till the volts were write now mine is 118-121
Posted on Sep 23, 2010
  • yea right Sep 25, 2010
    voltage problems have nothing to do with the red,green and blue aligning on your tv if your tv is already turned on.
Can't figure out to find auto convergence on remote or tv
Go to menu then setup look for convergence if you do not see it listed you have a open fuse FL231 it is located on right side of FBT flyback transfomer there is 3 in a Roll small brown rectrangler looking caps but they are fuses it will be the one in the Middle.
Aug 22, 2009 | RCA R52WH73 Projection Television
Model R52Wh74 RCA and we have blue color all on the screen
Have you tried to do auto convergence and see if that helps? If not try manual convergence adjustment
Jun 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the convergance amp?
Accros the top of the chassi.conv power supply is to the left
Apr 23, 2009 | RCA HD52W58 52" TV
I need help: Snowy picture/Bad convergence problem/Turns itself o
Have you tried the TV in more than one outlet to make sure it is not an outlet power issue?
Apr 11, 2009 | RCA R52WH76 Television
fl231 is solderd in and will have to be replaced along with DL231 and CL230
Apr 07, 2009 | RCA Televison & Video
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
