Question about GE GTS22KBP Top Freezer Refrigerator
Our frig won't go below 44 degrees. I've checked the coils and they are frost free. The freezer is working fine. Is it a thermostat problem?
  • 86 Answers
It sounds like the condenser coil is dirty. That's the coil under or in back of the frig. Other than that check the door make sure it's closing and the door gasket is not ripped. It may be letting in warm air. If the t-stat clicks when you turn the dial it's working.
I hope this helps.
Posted on Aug 24, 2010
My ge frig side by side the frig side 65 degrees why need help model number tfx22zrxd
You probably have a defrost problem -accumulation of frost on the freezer back panel. check for frost first then ask additional questions.
if no frost exist, check the condenser motor under the fridge and also clean the coils.
Jul 07, 2015 | GE Refrigerators
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
Freezer works fine but frig does not get cold at all
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall.  On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture oneexample picture twoexample picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Apr 03, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
In addition to the popping noise/coils are froze with orignal
turns out the coils were not defrosting or at best working intermittently. I defrosted the coils and ordered a defrost timer the old timer continued to pop from intermittently.I replaced the defrost timer
and it quit popping and noew the freezer works fine temps range between 9 degrees F and
14 degrees f.
Jan 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
The freezeer works just fine, but the frige is only about 68 degrees. it is about 100 degrees outside here does affect operation.Frige and freezer have seperate temp adjust.
What is the temperature in the freezer? Anything below 32 degrees freezes water. Make sure condenser coil is clean and that air can flow over it freely. In the back behind a removable panel you will find the condenser. Clean it completely and make sure the fan operates when the compressor is running.. Also check for possible frost on the back wall of the freezer which would indicate a defrost problem. if there is frost there the problem is ether a bad timer, heater, or defrost thermostat.
Jun 11, 2008 | Frigidaire Refrigerators
Frig side by side problem
I rolled the frig forward enough so I could unplug the power cord from the outlet. Then
I removed the freezer back panel and found the evaporator coils completely encased in frost. I used hot water in a 20 ounce sqeezable water bottle to remove the caked frost from the coils. I used the back panel as a chute to route the water into a large square bucket I placed on the floor right in front of the freezer. I then disconnected the defrost heater and checked continuity with my meter on the Rx1 scale. Meter needle did not move when connected across the heater indicating that the heater was bad. Called the local parts supplier and gave them the numbers off the old part. They had it in stock for $27.31 so went and picked it up, plugged it in, put in the mounting screws, replaced the freezer back panel, and plugged the frig in. I turned both the freezer and frig thermostats to their normal position. Four hours after my better half got all the food back in the freezer and the frig, the temperature in the refrigerator was 36 degrees.
Feb 28, 2008 | GE GSH25JFR Side by Side Refrigerator
GE GTS22KBP Top Freezer Refrigerator Logo
110 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
