Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
My hard drive won't turn on at all. No lights come on. It was working fine the other day. Is there a reset button or something that I can try to fix this?
  • Acomdata Master
  • 27,725 Answers
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Posted on Aug 24, 2010
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
MY 360 HAS 3 RINGS AND WON'T WORK BUT EVERYTHING ELSE IS FINE.
THINGS TO TRY
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  4. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
If the above suggestion dose not yield results, i would use the link provided below to help fix this issue yourself.
CLICK HERE(XBOX 3RINGS FIX)
Jun 18, 2009 | Microsoft Xbox 360 Console
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
IBM T30, turns on now and then
Look for bios update, and for that buton in your back laptop is for reseting the laptop at factory seting (default seting) . for that with hard disk problem , put the hard disck on a external hard drive reader and see if is still ok, or maybe the hard is full with data, For bios password  try to find aplication KILLCMOS  and reset the password.AND for Fumestsu Try to start your laptop without baterry in just with cable power.
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
My DVR-625, wont even turn on.
at the time the hard drive problem came up the receiver would of went into recovery mode this can take a good hour for it to fix and can do nothing until it would finish on its own and take care of. Doing the power reset is just like unpluging the receiver. Try unpluging again for 30 minutes and plug back in again and just wait receiver should come back on its own. Don't hit any buttons. If not will have to send out to dish for repair. 800-333-3474 dish
Nov 22, 2007 | DISH Network DVR-625 DTV Receiver /...
One red light - Error: E 68 - Problem code 0110
i think i can solve this try this out
I just had this exact problem, E 68, and was about to call MS, I removed HD and let system reboot without it and it booted fine i rebooted one more time without HD for a total of two. I then tried to reinstall the harddrive and noticed that it did not want to snap in. I played with it a few min more and finally got it to snap in properly. I think it was not seated properly to begin with as it was down further on the back side than it was before i removed it. I also heard two distinct clicks as it clicked in at the rear and then at the front. Once i did that it fired back up with both my profiles and is now working again. my 360 is laying horizontally
not sure if this work but its worth a try
Oct 26, 2007 | Microsoft Xbox 360 Console
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
56 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
