Question about Fuji FinePix A345 Digital Camera
Fuji finepix 340 mem card
Why does the larger capacity mem card not work on my camera.
I need more mem and can't find less than 1 g
  • Anonymous May 08, 2008
    What is the maximum memory on an XD Card I can use? 2GB is too much.
    Scholar:
  • 125 Answers
Is the new memory card an SD HC card? It will have an HC logo; if it does, it won't work in most devices that used SD cards.
Posted on May 05, 2008
I have purchased a 2GB XD memory card for my FinePix A330 camera. My camera is showing "Card not Initialized". Can you please inform me of the procedure I need to follow to initialize. Thanks
Your problem is that your camera is totally incapable of formatting an xD card of that large a capacity. You have an older 3.3 megapixel model designed when the maximum xD capacity planned was 512MB and the largest capacity available was 256MB.
Your camera will work with a maximum 512MB xD card but cannot use larger capacities. 512MB should be plenty though as on the fine setting it allows you to store about 330 images and on the normal setting it's 665 images. On the two video resolutions it's about 53.5 minutes and 182.5 minutes although on the lower resolution the battery would run out long before 3 hours!
There are no firmware updates to extend the capacity as it's a hardware limitation in the camera itself. Even if it could handle larger capacities then the camera would become very sluggish in operation. There's even a noticeable slowdown in camera response when using 512MB cards, so I recommend that you stick to a maximum of 256MB (you can always carry extra xD cards with you if you want additional capacity).
If you would like a free download of your camera user manual then click here for one from the Fuji website.
You only have two fixes: replace the xD card with a maximum 512MB capacity (preferably 256MB), or replace your camera with one of the recent models which accepts the 2GB xD card.
I hope that I have provided you with a clear explanation and practical options to fix your problem. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 04, 2010 | Fuji FinePix A330 Digital Camera
Card not initalized
Is the card larger than 2GB.
If so its too big for the S7000.
The only solution to more capacity is 2GB xd card + 2GB compact flash card.
Or just use as many XD cards as you need.
Oct 10, 2009 | Fuji FinePix S7000 Digital Camera
S 5600 finepix fuji camera - card error
Test the card in another device(computer)to see if it works.If so the card capacity may be too large for the camera.
Sep 22, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
What if a new memory card wont initialize?
Hi
The reason you are having this problem is that the maximum size memory card supported by this camera is 2GB. Any card with a larger capacity - like your 4 GB card - can not be initialised by the camera.
For reference see
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Fuji/Fuji+Finepix+S7000+Zoom_Memory_Cards
Hope this helps. Please do remember to rate my answer. Many Thanks.
Jul 25, 2009 | Fuji FinePix S7000 Digital Camera
Finepix z20fd memory card won't load in slot
Have you ever dropped your camera??
If you have , this is why.
No need to buy a new camera just yet.
Try celotaping it in.
My mom had to do this , after it worked fine!
Dec 26, 2008 | Fuji Finepix Z20fd Digital Camera
Fuji finepix A340
a340 needs a firmware update from fuji to work w/xd cards that have a h or m on card-should work ok w/older cards-check mem card and update camera from website to make compatible w/new type card
May 21, 2008 | Fuji FinePix S5000 Digital Camera
I cannot get card to work in my fuji finepix a 340 says write error inserted Olympus Xd picture card . ASfter attemting to take picture, rec'd message that it could not initialize.
If your new xD card is an "H" or "M" type card, it is only compatable with the A340 following a firmware upgrade to the camera. http://www.fujifilm.ca/x3721.xml is a link to the software and steps you can take to perform the upgrade.
Mar 13, 2008 | Fuji FinePix A340 Digital Camera
My camera
Buy a new cheap mem card lol
Dec 17, 2007 | Fuji FinePix A350 Digital Camera
Fuji finepix a340-card error
Storage cards can go bad, but usually this happens only after a long period of time (years), or if exposed to a magnetic force of some kind.
You can try a few things to resolve it:
1. Try reformatting the card, if the device can process data on it.
2. Insert the card into a card reader on a PC to see if the drive can be read. If you can read the card, remove all data and empty the trash, then reformat it.
3. If you get an error on that as well, replace it.
It's not worth risking that you might lose your valuable pictures to unstable media.
Good luck.
Oct 24, 2007 | Fuji FinePix A340 Digital Camera
Write error
Hi, Sounds like a memory problem. You can try using the built-in menu utility function of formatting the memory (be it internal or external memory). Of course this will also delete all current files/photos in it. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 03, 2007 | Fuji FinePix Z1 Digital Camera
Fuji FinePix A345 Digital Camera Logo
51 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
