SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
SOURCE: panasonic kx-tg2357
Called Panasonic Support. The unit will NOT record voice messages whilst in talking mode.
SOURCE: Panasonic KX-TG2357 talking caller ID
To turn Talking Caller ID on or off
You can turn Talking Caller ID on or off for the handset and base unit separately. If
this feature is off, the unit will not announce caller names. The factory preset is ON.
Handset Talking Caller ID feature
1 Press [MENU].
2 Scroll to “Talk Caller ID” by pressing [d]
or [B], then press Select.
3 Select “Off” or “On” by pressing [d] or [B].
4 Press Save, then press [OFF].
Also Refer To Page 31 Of Your Owners Manual.
If You Do Not Have The Owners Manual It Can Be Downloaded Here.
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Using Fixya.com
SOURCE: On our Panasonic KX-T7633 telephone,
The first thing you need to do is press PROGRAM and the lit button. Is it really the extension of the person who is always lit? An unconnected digital port does the same thing, so you could have a misprogrammed button. To reprogram the button press PROGRAM the button and dial 1+ext number and STORE.
The other thing is that certain versions of software behave differently. We still have some verson 2's and 3's that show busy, but the 5's don't.
Carl
