My canon PCD320 printer cannot print, error massage is printer not connected check that your usb cable is connected. i disconnected the printer after turning it off and reconnecting several times but to no avail. there is no problem with the usb cable. i tested it with other another printer and it worked alright. help I, PLS
  • 472 Answers
Whenever you go to your Start button just click on the setting and select printer or faxes and check whether your printer is being identified by the system or not if not install the driver relating to the printer and check it in the Device Manager and also check if theirs a check mark on the printer and if not just right click on the printer and set as default printer and confirm whether its online and right click on it an set as offline and check the connection of the printer and go to the printer properties and check the port and print the test page and more thing click on the Start button and select the RUN option from the start menu and type as services.msc and click on ok. Which list out all the service and find print spooler and make sure whether its being started if not just right click on the option and start it and also set it as automatic.
Good Luck!
Posted on Aug 23, 2010
We use hp T770 HDD, error massage 79.03 when loading, after show preparing print system massage in a few minutes. ask for restart but after restarted the problem persist. please kindly help us if there any...
79 errors are often linked to firmware. Unplug the printer from power as well as any network or USB cables you may have plugged in. If the printer will restart without an interface cable connected then it is likely a bad print job. Clear all jobs from the print queues and then plug in the interface cable. If printer continues to stay at ready, download the current firmware and install it. This should resolve the problem.
May 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Offline printing from computer
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Oct 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
Error 5100
Issue: ERROR: Service error 5100 appears while printing from the computer
1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP180 may require repair
Try the above..
Oct 18, 2010 | Canon PIXMA MP180 All-In-One InkJet...
We have giant company & having CANON LBP 2900.Whenever i am going give print it,s not printed .message shown ready to print but error occuring please help
try checking the printer if it is installed properly, by going to the printers and faxes folder, right click lbp2900 and check its properties, verify if the port used is correct. check printer if it is online and also the usb connection. if everything is ok, try replacing the usb cable. if after replacing the cable and the printer still doesn't print, uninstall it and remove the connection. Restart the computer and begin installation, do not connect the printer unless the system prompt you to do so. Run test print after the installation.
Jun 22, 2010 | Canon LASER SHOT LBP-2900 Printer
What is error code 300 for Canon MX310
Error Code 300 is displayed.
1) Cause : The machine not ready.
Action : Confirm that the power lamp is green.
If the power lamp is off, turn the machine on.
While the power lamp is flashing green, the machine is initializing. Wait until the power lamp stops flashing and remains green.
If the Alarm lamp is orange, an error may have occured on the machine.
2) Cause : Machine is not connected properly.
Action : Make sure that the USB cable is securely plugged into the machine and the computer.
* if you are using a relay device such as USB hub, disconnect it, connect the machine directly to the computer, and try printing again. If printing start normally, there is a problem with the relay device.
Consult the reseller of the relay device for details.
* There could be a problem with the USB cable. Replace the USB cable and try printing again.
3) Cause : Your machine is not selected in Printer on the Print dialog box.
Action : Select your machine's name in the printer on the Print dialog box.
If your machine name doesnot appear in Printer, follow the procedurebelow to check that the driver for your machine is installed on your computer.
a) Select Print & Fax Preferences in Printer.
In Mac OS X. v.10.2.8 or 190.3.x, select Edit Printer List in Printer.
b) Check that your machine's name is displayed in the list of printers and that the check is selected.
In Mac OS.X v.10.2.8, check that your machine;s name is displayed in printer list.
c) If your machine's name is not displayed, click Add(+) to add the machine. If you cannot add the machine, follow the procedure described in youe setup sheet to reinstall the MP drivers.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mp160 printing problem
Here is the straight scoop for fixing your problem from the Canon website:
Issue: Unable to print from the computer when an error message is displayed
1. Configure printer driver to correct port 2. Disconnect and reconnect the USB cable to ensure a secure connection 3. Disconnect other device and reboot computer 4. Remove [Other device] from Device Manager
Hope this helps.
halthefotoguy
Jan 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Sep 11, 2008 | Canon imageRUNNER 400S Copier
My printer show this code 2 E 7
I have problem with my scanner.
when I want scan whith that show this message:
cannot communicate with scanner
cable may be disconnected or scanner may be turn off.check status.scanner driver will be closed. code : 21550
please help
Jun 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
55 people viewed this question
jasbo
jasbo
