Question about Kenmore Ovens
Have kenmore radiant convection oven. trying to broil, getting F9 error message, sometimes "door" appears, and oven will not stay on. rogermmccoy@hotmail.com
  • Kenmore Master
  • 8,220 Answers
F9 Door Latch Error:
Check latch and latch circuit.
Posted on Aug 23, 2010
I get an F9 error message when I try to set the oven to bake.
THis is what the F9 error code means;
F9 Door latch failure Replace door latch switch or assembly if necessary
Aug 20, 2011 | Ovens
My fan has stopped working can i still use the oven,grill and stove
your oven will still work, just not on convection. you can still bake/broil with radiant heat from the oven
Aug 12, 2011 | Ovens
When I try to set a temperature, F9 appears. I have tried to turn off power by flipping circuit breaker. The power was off and I set a temp, then turned it off and F9 appeared again with "lock." Any...
The most common cause of a F9 error code is a problem with the door latch circuit. There could be a pinched wire for the circuit causing a short or the door latch motor is defective. Sometimes a problem with the ERC can cause this error to appear. Possible problems can very slightly from manufacturer for this error code but almost all use the F9 error code for the oven door lock.
Jan 14, 2010 | Ovens
Oven door won't unlock
kenmore selfcleaning oven door will not unlock code f9 appears in window
Jan 03, 2010 | Ovens
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Ovens Logo
53 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
