How does the honeywell thermostats work if i change it from teh regular one to a programmable onw. will the pins slide right back into place or do i have to move the wires and adjust them?
    Scholar:
  • 149 Answers
No its usually a whole unit if you change it but if you change it just remember where all the wires go! look at all your previous wires and you are going to connect them the same way.
Posted on May 05, 2008
How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jan 10, 2015 | Honeywell T8001C1019 Programmable...
The digits are not showing and I have changed the batteries
Remove the cover to ensure the batteries were installed correctly. If they were, make sure none of the thermostat pins are bent a little cause mis- alignment with the pin-holes in the subbase. When you determine all is good, reinstall the stat to the base and make sure it is snapped securely in place.
Jan 01, 2015 | Honeywell Electronic Programmable...
Honeywell thermostat short and then went blank by mistake i short the thermostat with a wire and then became blank
Check the transformer in the air conditioner/heater. There should be a fuse on teh 24 volt side. Shut power off to the furnace. Locate and check the fuse. If there is no fuse, you probably destroyed the transformer.
Jul 17, 2010 | Honeywell Programmable Thermostat Heater
I changed my wall thermostat to an updated honeywell thermostat and now it doesn't work. The wires are all color coded and in the correct slot. The old one doesn't work when I put it back on. I reset the...
Hi, just off the top off my head, is your fan/filter door in place? There is a safety switch on the door that prevents the heater from running without it. Good luck
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
The fan won't change to "auto"
i have worked on many honeywells and the button slides from on to auto but you have to push very firmly to get it to move
Aug 06, 2009 | Honeywell Programmable Thermostat Heater
Screen frozen TH8320U1016 honeywell
I got mine to work! Mine is the th8110u1003 and although the screen seemed to display, it was completely unresponsive to touch. Long story short, there is a flat watch battery behind the screen. Get to that and remove it for 15 seconds and reassemble. It powered right back up!
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Pins on back of thermostat one broke off inside unit weld broke
has it always worked or did you just put it in some require 24 volts to work a wire from the thermostat to furnace c terminal
Apr 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
