Question about Orion 1.25"/2" Precision Rack-and-Pinion Focuser Telescope
Violent thrashing steering wheel after 3-4 minutes of running
We've utilized a reman. T-Bird R&P in conjunction with a Saginaw pump...An aftermarket pressure valve to replace OEM was recommended by "Speedway" rod parts so it was purchased and installed .. After starting the car and allowing to run for approximatley 3-4 minutes the steering wheel will thrash left to right violently and can NOT be physically held . Any ideas as to what the problem may be ? Everything purchased was either remanufactured (T-bid r&p) or new (Saginaw pump and pressure valve) ... my direst email address is ; Chuck_Darnell@comcast.net
Thanks,
Chuck
    Genius:
  • 1,027 Answers
Not a telescope problem, but I think that the pump hoses are reversed!
Posted on Sep 19, 2009
Canon PIXMA MX920 error code C000
After market units do not send the proper signal as factory cartridges so put the AfterMarket ReMan back in, Un-Plug the unit for 3 minutes . plug it back in and maybe the computer will accept the reman, just will not show "quantity".
Oct 03, 2014 | Canon Pixma MX922
Steering wheel and tire issue
Have a front end suspension check done to eliminate any worm ball joints -shockies- worn suspension rubbers-- steering problems. If ok have a wheel alignment done and have the rear end aligned first as it affects the front alignment. The violent wobble is castor wobble and indicates negative castor possible from sagging suspension springs. The camber is out at that results in the car following every dip in the road. The camber has to work in conjunction with the toe-in measurement and if the 2 are not correct then you will have problems.
Nov 20, 2013 | Ford Cars & Trucks
"power steering pump repair on dodge 318"
This truck uses GM Saginaw power steering pump (best pump in the world).
This pump is show being rebuilt on Youtube, the year is of no matter. it is the same pump except your is not the metric bolt type.Click here
Oct 04, 2012 | Cars & Trucks
Power steering box that will interchange with 1965 Rambler V-8
ramblers were a mixture of the" big three" back in the '60s you might see if a steering box from a dodge ram series pickups or ford f series pickups may fit. also,check closely on the steering box for a casting number,parts suppliers use these numbers as a cross reference to match other steering boxes to your application.
Jan 20, 2010 | AMC Cherokee Cars & Trucks
Have saginaw manual steering gear box on 70 pontiac t/a. steering seems a little loose. how do i adjust saginaw box
There should be two adjustments on your steering box. Loosen the large ring nut at the end of the box and tighten the center adjuster to zero clearance. When re-tightening large ring nut, make sure that adjuster does not turn with it (sometimes it helps to adjust a bit looser so the adjuster ends up where you want it) You will also find another adjustment on the cover opposite the pitman arm shaft. Adjust with wheels off the ground and make sure that after adjustment is made box does not bind. If any binding is noted, back off a bit.
Jun 08, 2009 | 1979 Pontiac Firebird
I have a 1999 Ford Ranger 2.5 L 4x2 and after i start the truck there is a slight hum and it gets louder when u speed up the rpms, it also gets really loud when i turn the steering wheel so i replaced the...
Ford Saginaw pumps are notoriously noisy power steering pumps. I have not had any that were not noisy. This is especially true when turning the steering wheel without the vehicle in motion.
It sounds like you may have a bearing race out of spec in your front hub assembly. Check for bearing play by pulling with your hands on each tire--if there is a clunking noise---replace the bearing.
Mar 26, 2009 | 1999 Ford Ranger SuperCab
Hi, I'm trying to put a new flaming river steering shaft onto my 1984 CJ& with the power steering. The new shaft has a 3/4'' yoke and 36 spline count, but I cannot for the life of me get it to mount on the...
check the splines for consistency as many have a master spline ( one wider or like 2 as one) so that the steering wheel always ends up in the correct position
you may have to fit a different yoke to the box to take the new shaft
Apr 16, 2017 | 1984 Jeep CJ7
Orion 1.25"/2" Precision Rack-and-Pinion Focuser Telescope Logo
67 people viewed this question
Top Orion Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
