Question about Canon PIXMA MP780 All-In-One InkJet Printer
Wrong cartridge message - Canon PIXMA MP780 All-In-One InkJet Printer
  • 6 more comments
  • hal9 Jul 14, 2008
    Printer was working fine until the infamous "Wrong Cartrige" error appeared. I have heard others say that replacing the head works. Is there no way to simply clear the error? It seems unlikely that the head is really defective unless it is designed to do just this after a time.
  • Anonymous Aug 13, 2008
    cartrige error
  • curtiscabine Aug 25, 2008
    I keep getting "wrong cartridge" message. Printer was working fine until this happened so it is unlikely I now have the wrong cartridge. I cannot clear the message. I have tried unplugging the printer. Do I need a new print head??? It's hard to get my paperwork done without a printer. Help!!
  • donlyn Aug 27, 2008
    Removed and replace cartridges, nothing worked. Tried to change settings and it also did not mak any difference
  • keddie82 Oct 21, 2008
    I have the same problem. I have 2 identical printers. I swapped the print head. I get the same error on the same machine.
  • Anonymous Dec 09, 2008
    Our printer was working fine. My husband had just printed 50 pages a few days before without a problem, then my daughter tried to print something and the "wrong cartridge" message popped up. I tried shutting it off and then I tried replacing the ink, nothing will get rid of the message.
  • Anonymous Dec 27, 2008
    brand new printer - got this error message with the supplied equipment. Very helpful.
  • Ausfixer Mar 30, 2009
    Same problem - tried cleaning but did not fix the problem. Will try a new print head.
Ok, i have that problem. I just remove the ink, and the head cartridge, it is in one piece with kind of electrical contact on it. Nothing to unscrew, just slide it out after you have removed the 5 ink. I then clean with remover the brass contact, and I wash everything under my batroom tap, with hot water for , until no more ink appears. Then I dry carefully the head cartridge with a hair dryer. I put everything back and the error message dissapear. I perform few maintenance like head cleaning, , and everything was fine. I think, the brass contact and the water that remove all ink solve the problem. Work like new
Posted on Jan 12, 2009
Try replacing the printhead with a new one. I had same message and tried everything. With new printhead works like new.
Posted on Oct 21, 2008
Same problem. Anyone? Canon?
Posted on Sep 17, 2008
Computer says that the cartridges are in the wrong slots- which they are not. I have tried switching off and on -no effect, same message.Error 1102 The only thing that is different than usul is that I...
Turn the printer off.
Disconnect the AC power cable from the wall-outlet, to make sure that is "100%-OFF".
Reconnect it.
Remove that #33 cartridge.
Does that get rid of the "wrong" message?
Reinsert that #33 cartridge.
Does that message still appear?
Have you returned the "defective" #33 cartridge to where you bought it, and gotten a replacement for it, and installed that replacement cartridge?
Mar 25, 2011 | Lexmark X3650 Printer
Canon mpc 200 error message ''wrong cartridge'', won't print
if you have the old cartridge still check the connection to see if it is the same as you had and check to see if you have an original or compatible cartridge as some wont be recognised.if there is an electrical connection board in it see if you can change it onto the new one
Jul 31, 2009 | Office Equipment & Supplies
Wrong cartridge message always on
Wrong cartridge means you need a new printhead. qy6-0049-000. Around $59.00. Cartridge in this case refers to printhead, not ink cartridges.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Alarm message wrong cartridege
You just need a new printhead, wrong cartridge on a Canon means the printhead is worn out.
Apr 29, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Wrong cartridge message pops up and won't print because of it
Even with new cartridges sometimes the pc board that is attached to the cartridge can get dammage,replace the faulty cartridge.
Jan 07, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Wrong cartridge
I have the multipass mp700 and have just experienced the same message ..... wrong cartridge. After reading the manual, from the disc, it means that there's something wrong with the print head, most likely needs cleaning, but it won't clean because the printer is sending a malfunction message. I will be trying to clean the head and if that doesn't fix it then I'll buy a new print head. Good luck with the problem.
Aug 15, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Alert! Wrong Cartridge message
If you are absolutely sure that cartridge is installed correctly, the contacts where cartridge may be dirty. Clean gently with soft lint free cloth with small amount of rubbing alcohol and retry. If problem persists the contacts may have been damaged.
May 09, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
1,094 people viewed this question
old marine
old marine
