Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
My Sub-Zero is flashing error code 36. What is this?
  • 28 Answers
36 is the temperature not a Subzero error code. If it is flashing EC the error code is the number to the right of the EC. It will alternate back-and-forth from error code to temperature inside the unit. For example EC 24. Is an error code 00 36 are the freezer and refrigerator temperatures. Temps and error codes may vary. But subzero does not have a code of 36.
Posted on Jun 02, 2015
  • 37 Answers
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Posted on Aug 23, 2010
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
Sub zero ref 690 s model with error code ec 50 what is that
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
My 650 sub zero vacum condensor error code is flashing and the refrigerators inside temp rose to 58. Should I try and clean the coils first or does this sound like a more serious problem
Good day,
Cleaning the coils on a Sub Zero should be a routine procedure.
At least once a year.
Unfortunately the depth, fin design and overall layout of the Sub Zero machines does not lend itself to vacuuming.
The coils, to be cleaned properly must be blown out, from both ends.
Service techs carry nitrogen tanks or air under pressure with a hose to do the job.
If you do not have access to one of these devices, a quality push/pull shop vac with a crevice tool and some patience will do the job.
It's ugly and messy but there is no other way to do it properly.
It should be done as soon as possible, and if it produces no results on frig temperature a service tech qualified on Sub Zero should be called since it could easily be a serious problem.
Mar 10, 2010 | Sub-Zero 650/SRH Stainless Steel
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Jan 21, 2009 | Sub-Zero 700TR
Wolf electric cooktop
This is what Sub-Zero has to say (sounds like techno-gibberish)
Looks like it's technician time -
CT Induction Cooktop Error Code E13
Jan 04, 2018 | Cooktops
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
589 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
