Question about Kenmore Ovens
F3 pops up and turns off - Kenmore Ovens
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 24, 2010
F3 error code
Bad oven temp sensor. If you know how to do so you can disconnect the power and remove the temp sensor. The two white wires to the sensor, ohm it. it must read ~1080 ohms. If not really close to that at room temp then replace sensor.
Dec 11, 2013 | GE Profile JT955 Electric Double Oven
Whirlpool gold oven message E1-F3-
whirlpool oven starts preheating then turns off and sends a message F-3
Nov 13, 2013 | Whirlpool Ovens
KEBS207D double oven has F3 pop up and fan stays on
Hello & Welcome to FixYa
F3 error indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 27, 2011 | Ovens
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
Onen display shows f3
The F3 error code relates to the oven temperature sensor and usually means this has failed and needs to be replaced.
It is a reasonably straightforward job, details of which you can find here; www.fixitnow.com/2003/02/appliance-tip-of-the-day-oven-temperature.htm
Jan 18, 2010 | Ovens
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
F3 F3 F3
F3 code means "The oven temperature sensor is open". Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
If your not sure how to do this, I recommend calling a professional to get it fixed.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
93 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
