Question about Fuji FinePix Z10fd Digital Camera
Zoom error when you turn it on. lens comes out and goes straight back in. have removed the battery for over 1min but made no difference to it. camara is only 8 mths old.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 10, 2010
The zoom won't come out when I try to turn my camera on, it just turns a little bit, then turns back to the original place, and the screen says zoom error. I've tried different batteries, and taking out...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 14, 2010 | Cameras
I have a zoom error alert on the screen of my fuji j37 digital camera. When i turn the camera on the lens comes out and retracts straight away.
I had this problem for the first time yesterday, on my fifth use of the camera from new. The user manual says to turn it on and off a few times which I did but to no avail. I found advice on a different forum that said to hold your finger over the shutter as you turn it on, so that the lens doesn't have time to retract again. Sort of use your finger nail to hold the shutter up while the lens extends. Tried this and it worked, switched it off and back on agiain and it seems to be going fine now.
May 16, 2010 | Cameras
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens Error
HI MY CAMARA IS TURNING ON EJECTING LENS THEN IT GOES BACK IN RE SPITS LENS OUT THEN COMES UP WITH THE LENSE ERROR I HAVE PUT NEW BATTERIES IN REMOVED THE CARD BUT STILL NO JOY WHAT DO I NEED TO DO.
THANKYOU
JULIE
Feb 22, 2008 | HP Photosmart M525 Digital Camera
Zoom error
I just got one from Newegg.com. It was a refurbished item so I knew I was taking a chance. Straight out of the box it gives me a "zoom error" and will not take pics or even display an image. From what I've read about this it is most likely something in the zoom mechanism and needs to be fixed by the factory.
The only thing you can do is send it back to be fixed. I know this isn't much of a solution.
Dec 15, 2007 | Fuji FinePix S5700 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
27 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
