Question about Whirlpool LHW0050PQ Front Load Washer
I have a whirlpool lhw0050pq4 washing machine. After it fills and starts its cycle it stops and the start button flashes. I can't get it to complete a wash cycle. I can turn the dial to spin and the pump motor comes on and empties the water but thats about it.
catriver
  • 878 Answers
SOURCE: Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Posted on Apr 15, 2007
SOURCE: indesit w113 fills with water and then dial just spins to number 9
test the element
Posted on Jan 15, 2008
  • 1028 Answers
SOURCE: My whirlpool LHW0050PQ4 compact front
probably motor control bd but on some early models when both control bds (1 under top and 1 under bottom panel)came together in a kit worked great since sometimes hard to determine exactly which control bd was actually causing the problem if you are sure wash motor is not running and belt is not off
Posted on Jul 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
My whirlpool LHW0050PQ4 washer door is locked and unable to open, wash cycle is finished. Unplugged overnight and return next day, still locked. Any suggestions?
reset it
push sound for 10 secs
or
open top
spline screws top back
an reach down to the door latch
bottom of latch t is a small loop for your finger to pull/push it down
you can get to it same way from the bottom front cover
unplug unit
3 spline screws on bottom front washer cover
reach up an pull the loop on latch
good time to clean out the trap since your (t)here.
May 13, 2014 | Whirlpool Washing Machines
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool adp 9411
If this is the machine with just a knob for the wash cycles, and one button to start the wash cycle, you will have to replace the timer. There is no reset that I know of.
Dec 16, 2013 | Dishwashers
Whirlpool deluxe WFW9150ww01
Replace the analog level pressure switch, it sounds like it is bad, and the machine's overflow switch is the only thing stopping the fill from flooding your house... Whirlpool Washing Machine Pressure Switch WPW10239066
Jun 04, 2013 | Washing Machines
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool duet Washing Machines
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
