Question about Philips 32PF5320 32 in. HD-Ready LCD Television
Philips 32pf5320/28 Cannot get digital signals from antenna. Do I not have a digital tuner? Also, sound mutes itself. have to turn off and back on to restore sound
guide2u
  • 461 Answers
SOURCE: philips HTS3440/37
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Posted on Sep 07, 2007
ctf1800
  • 4402 Answers
SOURCE: can I get a digital tuner for Philips 51PW9303 51 in.
have to purchase a third party tuner for my tv.
Posted on Jan 24, 2008
DickCanFixIt
  • 948 Answers
SOURCE: No signal without a digital convertor box.
You must have a tuner, but the one built into the TV will work fine. Have you scanned for available channels after connecting your antenna?
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Posted on Jan 16, 2010
SOURCE: analog to digital conversion for LCD TV
Bought a conversion box!!
Posted on Feb 09, 2010
Have lost all channel 2 stations
I assume you are having a problem with OTA channels. On some TVs, if a digital channel doesn't have enough signal strength, the channel list will get edited to exclude it. Have you checked that your antenna is pointed in the correct direction? My external antenna sometimes turns in high winds. Turning it back to the original direction improves the signal strength so that the tuner works. Then go into the Menu and find the Setup or Channels sub-menu to attempt to rescan for channels. (If you add a comment with the model of your TV, I may be able to give the specific sub-menu details for scanning for channels.)
If your antenna has an amplifier, try using the antenna without that amplifier. A few times, the amplifier/splitter attached to that external antenna has been damaged. Then the amplifier becomes a filter and blocks some channels. If you are far enough away from your local station's transmitter and can't receive the signal without the amplifier, replace it.
If another TV receives the stations, the problem is more likely to be the tuner for the TV itself. These can be damaged by a surge from the antenna. The solution is to get a set-top box with an ATSC tuner or replace the TV. Some sites may have replacement tuners (like shopjimmy.com that salvages parts from TVs with damaged screens); however I don't know if they'd have the part you'd need.
I hope this helps.
Oct 15, 2015 | Televison & Video
Hi, my name is Milan. I have a sony Bravia 55 w950b TV that has lost antenna signal
Sounds like defect is with its tuner itself, as you suspected. Contact any service technician.
Electro help
Sep 07, 2014 | Televison & Video
I can't operate my Philips Magnavox 42MF521D/37 Television
Philips has the FAQs and manuals for the 42MF52D/37 here: http://www.m4c.magnavox.com/cgi-bin/cpindex.pl?ctn=42MF521D/37&mid=Link_FAQs&scy=US&slg=AEN . The direct link to the User's guide is http://download.m4c.magnavox.com/files/4/42mf521d_37/42mf521d_37_dfu_aen.pdf . You will need Adobe Reader of a similar program to read the manual.
Is there a specific problem you are having with your set? (OTA or cable setup or another issue) Please add a comment if you would like additional support. Note: digital OTA signals are subject to a "cliff effect" if your tuner doesn't get enough data from the antenna. This will be determined by the tuner, the antenna location (indoor, outdoor, elevation), distance from the transmitter, and any splitters or other wiring problems. I've seen failed amplified splitters turn into filters that block the incoming signal from reaching the TV.
Dec 16, 2012 | Philips Magnavox 42MF521D/37 Television
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
I purchased the PT902/37B and charged it of course. Turned it on for the first time and the instructions say I have a no/weak signal, I reconnected the antenna and still nothing. Can you help? Thank you,...
U follow the tv owner manual instuctions for scanning for the DTV free over the air broadcasting by the tv stations signal yet.Do that first,still have a message weak or no signals.Buy a newly design Digital antenna or have a roof antenna already hook it up to the tv,follow the owner manual rescan it again will have all DTV free over the air broadcasting tv channels.
Jun 13, 2011 | Philips Televison & Video
The picture freezes and the sound is lost. Until the picture returns and the sound returns,this happens every couple of seconds.
If you actually have the Zenith model TV (B25A24Z), the trouble is not in your set. This model has only an analog tuner, and what it sounds like you are describing is digital pixellation. This is what happens with a digital-to-analog converter box when it gets a weak signal, with rain fade or heavy snow on a satellite dish antenna, or when a digital cable system has some signal problems. The converter equipment locks the last complete frame (or breaks up into blocks and freezes) and the sound is muted.
You'll need to look for the cause of your trouble in whatever is feeding the TV. If you have a digital converter box for off-the-air broadcasts, make sure you have a good antenna and all the connections are tight. If you have satellite TV service or digital cable service, you might need to contact your service provider for help in troubleshooting and fixing the trouble.
Dec 19, 2010 | Zenith B25A24Z 25" TV
Philips 51PP9100D/37 Will Not Stay On
o.k. your internal digital tuner sounds like its goin. what you need to do is take the back cover off and trace where you hook up your
digital signal (cable,ant.hdmi).then you will see 2 silverish boxes one is analog,other digital. get refrence #s off of board of the tuner thats conneted (trace the signal input wire to be sure) then e-mail me ohmega1080@yahoo.com
Jun 21, 2009 | Televison & Video
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Indoor antenna problems
I don't know the menu system on your model, but you have to check that the tuner is in the proper mode. Also, some of the new TV set models cannot receive a standard analog TV signal from its tuner.
As for the distance from the transmitter sight, this depends mostly on the antenna quality, antenna location, the power output of the transmitter sight, compatiblity of the TV to the received signal, and also the capability of the TV's tuner.
Modern TV sets are really designed to be used with a satellite or cable TV box with their respective service.
Terrestrial TV is dying out, and in a matter of a number of years, it will be gone.
Jerry G.
May 24, 2008 | RCA F25645 25" TV
No signal
That sounds about right my friend. Those sets do have two tuners and Ive seen the problem your desribing. Unless of course that the microprocessor and tuning circuits are goos also. I would call a servicer if I were you unless yopu know your way around the inside of the tv set as it does have alot of High voltage even when its unplugged Good Luck
Jun 07, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Philips 32PF5320 32 in. HD-Ready LCD Television Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
