Question about Dell Inspiron 1525 Notebook
Disc/CD will not open. Seems computer doesn't recognize that it's there!
    Scholar:
  • 166 Answers
If the LED is flashing when booting. Look for a pinhole on the drive and get a pn that fits on it, insert and push.This is the emergency eject.
check my computer if its there. If not follow this.
1. Run Regedit
2. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. Delete Upper and Lower Filters on the right hand side pane.
4. Exit and restart.
Posted on Aug 24, 2010
  • Ronan Reynera
    Ronan Reynera Aug 25, 2010
    Please comment if the information has been helpful. Thank you and regards.
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
I hope this helps.
Mar 31, 2012 | Televison & Video
Can't find CD icon is missing from one computer
Windows Key-E will bring up windows explorer which should show your list of available drives.
If this doesn't show your CD drive then try removing CD from drive. Does the disc tray open? If so then reboot system without disc and try the above method to find cd-drive.
If this doesn't work you may need to involve more hands on trouble-shooting.
Thanks
Jul 22, 2011 | Staples 2x1 USB Peripheral Switch
The DVD writer doesn't recognize that there is a
Most DVD drives are also CD drives, and it sounds like the DVD part is broken, you need to replace the DVD drive, this is done simply by buying a new one, I recommend Newegg.com ( if your unsure search exactly what you already have) then opening your case (tower) and just unplugging old one and plugging new one in, it really is very doable for even a novice.
Jun 26, 2011 | HP Computers & Internet
My MacBook doesn't recognize my new portable LG Super Multi Drive--GP08 Lite...There's no icon, and things aren't burning...Do I need to download a driver? Why doesn't this product tell...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 25, 2011 | LG SecurDisc 8x External Double-Layer DVD...
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
I have a HP dvd/cd rom rw 1040d disc drive. The disc tray doesn't open when empty. It tries to open but doesn't manage to open. If I manage to get it open, (Usually manually when shut off, it will open...
Premature failure of this drive appears to be a widespread issue. I have joined in a support thread at HP and encourage you to do the same:
http://h30434.www3.hp.com/t5/CD-DVD/Hp-dvd-1040i-Disk-tray-doesn-t-open-half-the-time/m-p/347544#M1980
Sep 29, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
Won't recognize disc-cd or dvd
The pick up or in other terms laser is faulty if its not under garrentee start by opening the tray and clip of the tray`s cover open the writer and clean the lense with a ear bud and then test it if no response it gets more technical or its time to replace, i hope these tip help you
:)craig
Jan 09, 2008 | LaCie 300722 DVD±RW Burner
Dell Inspiron 1525 Notebook Logo
12 people viewed this question
Alun Cox
