Spin Cycle inoperative. New Switch-Lid part has been purchased; however, how do I get to the part to replace it?? Can I remove the top of the machine? or do I have to go thru the back but removing the entire back panel???? Please help...wife need clean clothes
  • Washing Mach... Master
  • 2,605 Answers
Hello, Welcome to FixYa.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
Let me know what you find and if I can assist you further.
good luck.
macmarkus :)
Posted on Aug 23, 2010
LG top loading washing machine spin not work n
Try test your lid switch. If the switch is inoperative, the machine will not spin or drain when it gets to that cycle on the timer
Sep 25, 2014 | Washing Machines
Washer washes then does not spin out
replace the lid safety switch by removing the control panel,then unplug the switch harness under the panel then remove the 2 brass colored clips on the top and tilt machine toward you to access the switch under the top by the lid,its there to shut machine off if the lid is opened during spin cycle
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer was purchased new in 1989. Are parts still available?
The problem is your lid switch. That "hole" you mention that you are putting a wedge in is where the lid switch is. It is activated by a small acuator on the washer lid that pushes down on the lid switch when the lid is closed.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
Sep 03, 2009 | Washing Machines
The washer does not drain the water or spin. Does the drain work when the spin cycle starts?
pull end caps from both ends of back splash remove 2 screws flip control panel back...remove 2 clips(use screw driver to pry up)...disconnect wire plug lift lid put hands in opening pull the case to you and up to remove entire case...remove 2 screws that hold lid switch install new switch...(don't forget to plug the wire plug back in...ho ho
Aug 26, 2009 | Kenmore 23822 Top Load Washer
No spin cycle
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Aug 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Machine will not advance to the spin cycle in the normal way on any of the different wash cycles available on the timer. I thought it was the timer, so I replaced it with a new timer. Same problem. I've...
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. NOTE: Since you posted no brand name or model number, the instructions I provided the best instructions I have. These steps are for any Whirlpool manufactured top loader. This includes Kenmore, Estate, and Roper. If you need further assistance, or if your brand name is not included, please post back with your model number, so that I may assist you better.
Aug 11, 2009 | Washing Machines
I need to know how to replace or fix the spin cycle on a kenmore 80 top load washe, the waser will not spin.
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
Jun 28, 2009 | Kenmore 23012 Top Load Washer
Washer gets to spin cycle and stops. It appears
Hi, if this is a whirlpool model machine, you can't just remove the top. The whole cabinet needs to be removed. You can change the lid switch without removing the cabinet. Remove the two screws holding the lid switch. Pull the lid switch toward the middle of the opening and snip the wires. You can splice the new switch onto the old wires using wires nut connectors if you want. If you want to use the whole wire harnes that comes with new switch, remove the two screws that hold the control panel to the cabinet. now yuou can see the lid switch connection (easy plug in) located in the middle. Unplug the lid switch and force the connection downward. Remove the old switch and install the new.
I can get you part# or send you the part off my web site www.whirlpoolpartssurplus.com if you would like. I would need the model#
I hope this helps.
THanks
Vic
May 15, 2009 | Washing Machines
Washer will not spin and drain
The washer stopping right after the wash cycle and then not advancing to the rinse cycle is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
May 08, 2009 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
