This page contains the following errors: error on line 55 at column 16: StartTag: invalid element name Below is a rendering of the page up to the first error. I'm on a Motorola DROID and this is what I get when I try to log on....
Did you manage to find out what the prob is? its happing to me on my iphone
Posted on Aug 23, 2010
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
From MS site:
Method 1: Follow the provided article.
http://support.microsoft.com/kb/308260/
Method 2: Reset internet explorer and check, whether the issue persists. Follow the steps mentioned in the article given below.
Reset Internet Explorer settings
http://windows.microsoft.com/en-US/windows-vista/Reset-Internet-Explorer-7-settings
Note: The Reset Internet Explorer Settings feature might reset security settings or privacy settings that you added to the list of Trusted Sites. The Reset Internet Explorer Settings feature might also reset parental control settings. We recommend that you note these sites before you use the Reset Internet Explorer Settings feature.
Feb 26, 2013 | Microsoft Internet Explorer 8
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
Can anybody help me figure out why I get the below message and how I can fix it? Thank-you Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR...
Internet Explorer 7 cannot display a particular element on a Web page on that Web site.
Workaround 2 loadTOCNode(2, 'moreinformation'); You can turn off friendly HTTP error messages in Internet Explorer. This workaround still lets the error message appear. However, Internet Explorer does not move away from the page after the error occurs. This workaround works only for Internet Explorer 6.
To do this, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to clear the Show friendly HTTP error messages check box under the Browsing section, and then click OK.
  3. Close the browser.
Follow this link for more workarround
http://support.microsoft.com/kb/927917/en-us
Thanks
Sandeep
Mar 16, 2011 | Microsoft Internet Explorer 8
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; InfoPath.1) Timestamp: Mon, 25 Jan 2010 20:30:47 UTC Message: HTML Parsing Error: Unable to modify the...
Within IE8, delete all Temporary Internet Files.
Close IE8.
Open IE8, and access Facebook's "home" page.
Does the error happen "all" the time, or only when accessing one specific friend's web-page?
If the latter, then there's a problem on that person's web-page -- avoid that page to avoid the error-message.
Jan 25, 2010 | Microsoft Internet Explorer 8
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
Aug 28, 2009 | Sage Instant Accounts 8.0 (013604ug)
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
Computers & Internet Logo
779 people viewed this question
David Payne
David Payne
