Question about Roper RAS8445KQ Top Load Washer
Model#ras7133kqo roper top loading washer it doesnt always spin out on spin without twisting it to get it started then it spins fine
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
rylee_smith
  • 8619 Answers
SOURCE: Roper top loading washer not spinning or agitating
Hi
If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
If your washer doesn't agitate, check these:
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 26, 2009
SOURCE: everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
Posted on Jun 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Posted on Oct 04, 2009
  • 126 Answers
SOURCE: Roper washer will not spin or drain-
you may have something stuck in your pump, preventing it from draining. The washer will not spin until it does drain. You'll have to empty the tub (you can do this with gravity by taking the drain hose and putting it down near the floor in a bucket). You will have to take the cabinet off, then take the hoses off the pump. Have some towels ready! Look inside the pump and hoses for an obstruction. If the fins inside the pump are damaged, you will have to replace it. If there is no obstruction here, look down inside the hose drain. Run a coat hanger down if neccessary to see if theres a blockage. The pump could be dead, too.
You could have a dead spot on the timer, but this is doubtful.
Posted on Nov 24, 2009
RAS6233KQ0 Doesn't Spin
Manually set it for SPIN and turn it on.
If it does nothing at all,
You have a defective lid switch.
Jumper the lid switch and see if it spins.
If yes, replace the lid switch.
Feb 27, 2009 | Roper RAS6233KQ Top Load Washer
I have a Roper brand top loader washer and it fills up but it won't drain or spin.
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Jan 30, 2009 | Roper RAK2751WWH Top Load Washer
Making loud noise and not spinning RAS7133KQO
its direct drive. you need to pull the pump and motor and replace the motor coupling. easy fix dont junk it.
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Roper Washer doesn't spin
If it is direct drive (no belt) it may be the motor coupling,
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Mo del RAB 1121EW1 serial number CG 402 1770
This is a direct drive washer so there is no belt. The drive coupler that connects the motor to the tub may need to be replaced.
Mar 05, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
