Question about Kettler Sport & Outdoor - Others
I own a Kettler Astro elliptical cross trainer and the main arm coming out of the bottom of the frame and up to the read out portion of the elliptical has broken off at the bottom where four bolts held it onto the frame, it appears the front part of the shaft cracked just below the portion that slides into the main frame. Can you help me out on this I never expected this to happen. I bought this product because Kettler was a top of the line product. I'm dissappointed I enjoyed this machine. My email address is ddrusert@verizon.net
greenspan
  • 1734 Answers
SOURCE: Manual for Reebok REV-11101 Fusion Cross Trainer.
If anybody can get the fusion cross Reebok manual, these are the right guys
Posted on Jul 06, 2009
SOURCE: Mains adaptor needed for an Olympus cross trainer
an adaptor can be purchased from anywhere really, maplins for instance...I have just looked at mine and its a 9v adaptor.
sorry I cant help with the instructions as I dont have them, if I do get a copy I will gladly forward them to you
regards
Posted on Mar 29, 2010
SOURCE: Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Posted on Jan 16, 2011
  • 5 Answers
SOURCE: how to access batter on
If you look behind the unit, (directly behind the digital readout) you'll see a small rectangular inset, if you look up in that (I used my cell phone light), you'll see a tab that you can pry with a screwdriver gently to release the computer section. Just keep one hand on top, when you pry it you'll feel the unit pop up, then you can lift it out. It takes 2 AA batteries, thankfully not some bizarre disk batteries :)
Btw when you look at the readout, you'll notice it's set in a silver square- that square is the computer module that pops out.
Hope this helps!
Posted on Feb 21, 2011
  • 356 Answers
SOURCE: Does Life fitness have an
Here is the operations manual:http://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=122335&name=DLFE-16196.pdf
You can find other guides from Life Fitness at their manual search site: https://www.lftechsupport.com/web/guest/user-documents
Hope this was helpful. If this wasn't what you were specifically looking for, please leave a comment explaining what you needed, thanks.
Posted on Apr 21, 2011
Someone gave me a Kettler Condor Cross trainer elliptical machine. Does not have any books with it. Don't need assembly manual, need to know how to turn on and off. Can anyone help??
I have had a lot of success searching manufacturer's websites for User's Manuals. Nearly all have them online in PDF format, A second source would be the Sears PartsDirect website.
Apr 17, 2016 | Exercise & Fitness
We relocated to Dubai and the electronic board is destroyed. Can we get a new one and would somebody in Dubai be able to install it?
Ask Kettler if they can provide an electronic board for your trainer. Yo have a phone number on webpage
Buy Elliptical Machines Cross Trainers Online Kettler USA
You should check if there is some good electronic repair service in Duba.
Or maybe you will be lucky and someone from Dubai might offer your service replying your question
Jun 28, 2015 | Kettler UNIX PX Elliptical Cross Trainer
User manual for Kettler 07854-000 "Orion" Cross-Trainer Elliptal
Try here
http://toolbox.kettler.net/fileadmin/_kettler_dam_import/SPORT/Dokumente_-_Kataloge/Montage_und_Ersatzteile/Cro(ss)trainer/07854-_Orion_706f-1003.de,en,fr,nl.pdf
Oct 28, 2014 | Exercise & Fitness
I know that elliptical trainers are a good cardio workout but do they allow you to work your upper body?
Most elliptical trainers nowadays come with moveable arm handles. This gives you more upper body endurance and allows you to burn more calories.
Aug 02, 2012 | Exercise & Fitness
My Kettler cross trainer Mondeo gives me program error E2 on the display. Kettler has cleverly hidden any information about what this actually means (so I can fix it). Thanks for any help you can...
E-2 FAULTS ARE PROBABLY DUE TO A FAULTY CONNECTION BETWEEN THE CONNECTING PLUGS-MINE WAS,I CHANGED A LEAD IN THE END AND SOLVED THE PROBLEM.PLEASE SEE MY POST ON THIS SITE ON THIS MATTER. MARK DAVIES
May 22, 2011 | Kettler Mondeo Elliptical Trainer
Display screen reading E2 what does this mean
E-2 ERROR COULD BE A POORLY FITTING CONNECTOR - SEE MY POST FOR MORE INFO
Mar 01, 2010 | Kettler Mondeo Elliptical Trainer
Sport & Outdoor - Others Logo
206 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Bill Eager
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
