FixYa.com
Tags:
E-Machines T2240 PC Desktop
T2240 cannot get the restore cd's to start
posted by swifty538 on May 04, 2008
When i try to format and restore i cannot get the disc's to began.It just does a normal boot. Cd drive does work though.
Comment by swifty538, posted on May 05, 2008
I tried that before with no luck. Any other suggestions? Thanks
Melnavz,
Could you tell me if it makes a diiference if I have a new cd drive or not?
Thanks
Comment by swifty538, posted on May 06, 2008
I can use the cd drive fine. It just won't boot off cd when started. F9 doesn't work either.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
melnavz
Rank:Wiz Wiz
Rating: 84%, 477 votes
hello,
Yo need to configure in bios setup the first boot option. in the first boot press" F2 or delete" to go to bios setup.
in there select the CD ROM to boot first and then press "F10" to save and exit the setting.
reformatting and installing press windows the instruction is here;
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
may this help:
melnavz
PS: pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Comment by melnavz, posted on May 06, 2008
Please try examine first your CD rom, by connection to another computer or insert new cd disce on if the pc is still funtional.
If prove that the CD ROM is not functional maybe you should change the CD ROM.
try also pressing "F9" at first boot you will be directed to the boot selection.
melnavz
Comment by melnavz, posted on May 07, 2008
Did you set the first boot in the bios..maybe the disc got damage..can u show me a picture of your bios or the model of the board?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Desktops problems?
PC Desktops
disk drive no longer works
disk drive no longer works on... Answer This...
PC Desktops
I accidently un-installed my...
I accidently un-installed my... Answer This...
PC Desktops
i am running vista and
i am running vista and i cannot... Answer This...
PC Desktops
driver sound
realtek code4c al662 for... Answer This...
problem
i have emachines pc at home but... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
