Question about Vivitar DVR 530 Flash Media Camcorder
How do you turn on the light on the front?
On the front of the camcorder theres the bulb thing
for the light how do i turn it on
i havent been able to find out how.
the light so that videos are visible when its dark
  • 398 Answers
This camera does not have a light what is on the front of the camera is a flash, not a light. It is available when you are in photo mode but not in video mode.
Sorry!
Posted on May 05, 2008
69 turn signal problem left turn signal not working. right turn signal causes both to falsh
it's the grounds if they're both flashing fast it's definitely grounds take a test light and see if its got power goes through the test light grounded to the frame and if the light comes on then it's definitely your grounds
Jul 29, 2014 | 1969 Pontiac Firebird
TURN SIGNALS
Hi
Did you check the fuses for the turn lights? Do the
parking lights work? If the parking lights work then you probably have a
problem either in the switch or in turn signal module thing.
The burned out bulb is what might be causing it not to blink... if one bulb is burned out you gotta replace it, make no difference if front or back,the left blinker will not work if the left front or rear bulb is bad.
same with the right side. if the front right or rear right turn signal
light is burned out it will not work.....get replacing the bulbs.Hope this solves your problem.Please rate me if my solution helped you.
Regards,
bonefirediv.
Apr 12, 2014 | 1988 Ford Taurus
How to replace the front turn signal bulb on a 2004 toyota solara
Behind it by head light under hood gotta reach hand in there may have to remove few things to get to it. Need help firrcrkr24@yahoo.com let me know:)
Feb 13, 2014 | 2004 Toyota Solara
Can I change my dash board lights in a 2004 Chevy silverado
Never seem one to be honest but untill you take the dash out and have a look ? as newer cars use LED things and not bulbs ,sure you havent turned the dash lights off by means of a variable knob on the left side of the steering column
Jan 03, 2013 | Cars & Trucks
Left front corner light stays on
Sounds like a bad ground. Check the ground wire, or try cleaning the bulb circuit. If the bulb is good, it's most likely the ground. Hope that helps.
Oct 25, 2012 | 2001 Buick Century
I have no rear lights. There seems to be a short possibly. when you step on the brakes or have the head lights on the turn signals blink fast. All the front lights work fine just no rear lights.
the bulbs that are used are a plug-in style and you need to take them out and check the ends of each bulb. I had one doing the same thing, and the bulb was good, which didn't make sense until I inspected the plug-in, which had a burnt end causing the bulbs to only receive power intermittently. Check yours and you may just be looking at the same thing.
Apr 15, 2011 | 2006 Jeep Wrangler
Hi, small sidelight fron driver side keeps blowing/stops working (cayenne s 2004) any ideas?? Also limited slip lever no lights/function (non PASM car) any ideas - fuse?? Thanks
side light take it out and check the bulb connections ,bend contacts up a bit drop of engine oil and that should cure the light ,now as for the other thing i havent a clue ,if i car car in front of me i could sort it out but from spain ??
Oct 27, 2010 | 2006 Porsche Cayenne
Replace front turn signal bulbs
odd speed blinker is a message to tell you that a light bulb has burned or is disconnected. All front lights can be replaced from the engine compartment EXCEPT the turn signal :( .Unfortunately you will have to pull the headlight assembly out in order to reach the turn signal bulb. If the light was off since the assembly was replaced, there is a chance that the socket was simply left unplugged.
Apr 19, 2010 | 2002 Honda Accord
Turn signal makes the dash lights flash
97 chevy blazer left turn signal makes the dash lights flash then when i turn parking lights on left signal stays on constent when engaged
Jan 16, 2010 | 1995 Chevrolet K1500
How to turn on light?
This camera does not have a light what is on the front of the camera is a flash not a light. It is available when you are in photo mode but not in video mode.
Sorry!
May 04, 2008 | Vivitar DVR 530 Flash Media Camcorder
Vivitar DVR 530 Flash Media Camcorder Logo
67 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
