Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I need help still
Hey im new at all this broad band i got this modem and the cords and the phone line filter and all that suppose to come with it except the software cd that you install it with but how do i get services for it i hate to bother you with this you might think im dumb it is just i never had broadband before i dont know how it works or anything
    Sergeant:
  • 291 Answers
Beth31046:
you are not dumb!! , I just have to understand your needs.
1st- u received modem, card, phone line filters and no software cd.
one: Every telephone line (hole in wall) that u have a telephone connected to, unplug telephone, connect a " telephone line " filter, then REconnect the telephone, etc to the filter.
2nd-cards?? Did u receive a 'card' that goes inside a "Desktop" computer or whats looks like a credit card that slides inside [usually the side]of a 'Laptop'? If the card is for the Desktop, then u have to open the back of computer,[POWER OFF!!] find an open slot (nothing connected to it) It should have a metal cover with a screw, that prevents things from entering, unscred, take metal tab\cover off, replace with" card" and screw down. The "card" should have what looks like a telephone connector opening (that usually connects a telephone line) excapt the opening for "telephone" line is wider, larger. That opening takes a male\plug that is a little thicker\larger then a regular "telephone" line. 3rd- on the modem, there will be two openings in the back. one for the regular telephone in from the wall [Make sure that there is a filter in the wall with the telephone line]. and a 2nd larger opening for the (thick but not too thick) wire coming out from the computer "card" to the modem
You have to call the people (Embarq, AT&T, etc) that sent you the STUFF, and they should set you up.
if this helps, please tell the FixYa people that I helped you.
Chow,
Posted on May 05, 2008
Kx-tge474 Why do my new phones have static on all 4 hand sets?
if you are using a land line and have a modem connected to the same landline , it is possible broad band or ADSL interference frequency
there are filters that connect in line to the phone base station to overcome the problem
Oct 30, 2017 | Lands Phones
Connect landline internet
You require a router to be connected with the land line and a broad band company to supply the broadband for WiFi or use your built in fax modem to access dial up.
Jan 29, 2014 | Toshiba Satellite Computers & Internet
Can not phone out or receive phone calls bt say my line is ok, my broad band works ok but not my phone
When did it start?
You haven't mentioned what you hear when you lift the receiver and try to dial out.
Please try this: (A process of elimination.)
- Unplug your modem from the telephone line.
- Plug your telephone directly to the telephone line without going through the line filter.
- It should work OK. If the phone is not defective, you should hear a clear dial tone.
- Now connect your phone through the line filter and try to use it again.
- If it does not work then you need a new line filter for your telephone.
- If it works, then re-connect your modem back to the telephone line like it was before.
If the modem knocks out your phone again, please contact the modem supplier.
May 31, 2011 | Office Equipment & Supplies
How do i find my access point name my broad band t-mobile & im working with windows 7 if any one can help that would to great thanks
Your "access point" means the thing that your computer connects to in order to get on the internet. An "access point" can be the dsl modem, a router or switch inbetween the computer and the internet connection or the point of entry to the internet - depending on what you are using to connect and get on line.
You mentioned you have a broad band connection with t mobile. Is this the T mobile home service link that gives you regular phone service and internet? If so - what is the name of the box your connecting your phone and pc to?
What is the name of the equipment that t mobile gave you to use that broad band link?
Are you using a desktop or a laptop? Wireless connection? or a wired connection with a ethernet cable (looks like a phone cable but a little bigger on the plug end)?
To answer my questions go back to your original problem posted on fixya and use the comment or reply link in blue.
Mar 26, 2011 | Sony Computers & Internet
My att 2 wire keeps flashing red on and off for dsl and then the green wireless light goes off and internet goes down. I get a msg that the broad band cannot connect. I have checked and double checked...
Hi
This is Neo . Check the Filters in the phone line if you have installed the filter . if there is no filters before the telephone , install a filter . Whether the phone line are connected properly and check the wall point where the connection from the DSL and telephones . Check the cords and try changing the RJ11 cords . RJ cors the phone thin cords .
NOTE : FILTERS SHOULD BE INSTALLED FOR TELEPHONES BUT NOT FOR 2 WIRE .
Nov 02, 2010 | 2wire 2700HG-B Router (2700HGB)
I m using broad band. i want to answer the landline calls through my dsl modem. how can i do that?
Well,
with any broadbank connection, you can surf and talk at the same time... all you have to do is to make sure that the filter is installed on the phone line and that the splitter/2way pin is installed on the telephone wall jack... dsl cable should not be filtered.
run speed test @ http://primustel.blogspot.com
Dec 05, 2008 | Westell Wirespeed LiteLine 6100...
Modem cold to touch
hey hi,
frequent disconnectes suggest tat u might have an intermittent sync prob that might be due to,
1 )filter problem(filter is a small box ,it is also called as splitter that splits ur broad band connectivity and telephone line)
so try isolating the filter that isz
connect the cable runnin at the back of ur modem directly into ur wall jack.
this will probably solve the problem
2)next reason is , it might be a line issue pls cal ur broad band help desk they ll sort it out
ur modems temperature has nothing to do with this.
try this n let me know .
Oct 01, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Online
Hi GameGirl31,
In order for you to go on-line with the PS3, you will first need either broad band or DSL Internet connection. Once you have that, all you will need to buy then is a wireless router. You will need to hookup the wireless router to your broad band or DSL modem. Once you have done this, you have two option on how to get on-line. You can hard-wire your PS3 to the wireless modem or you can use the blue tooth wireless net-card that is already built into your PS3 to go on-line.
Sincerely,
Agent Xiong
Apr 06, 2008 | Sony Playstation 3 (PS3) Console
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
37 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
