Question about Brother HL 5250DN Laser Printer
Printer making a banging noise - Brother HL 5250DN Laser Printer
My X5470 makes a banging noise, and will not print. I put in brand new OEM cartridges, and it does not help. Is it dead?
Remove the cartridges from the printer. Close the cover. Then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in. When the printer turns back on and it's still making the banging noise, then it's a hardware issue in the printer. If not, reload the cartridges. If problem persists, it might be that encoder strip that's causing the problem. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
Makes a loud banging noise while the paper will only feed in an inch or so
A bang for a buck. July 25, 2009 8:06 PM RSS feed for this thread .... These paper noise-makers are pretty loud. And you can make them with ... It's just a folded piece of paper so it's pretty inconspicuous. ... more decibles per square inch than about anything else on this list, and hey, they shoot streamers! ...
ask.metafilter.com/128391/A-bang-for-a-buck -
Dec 04, 2009 | Samsung ML 1430 Laser Printer
The carrage goe "bang" then the displayy claims that a paper jamb caused the problem. However, there is no paper anywhere near the carrage. Any ideas? Thanks John
Hi there again here is the web site for you to troubleshoot your problem ok best regards michael
  1. Troubleshooting Printer Noise When printing, The HP Deskjet 600 series printer makes strange noises such as: ... periodically slams or bangs against the left side of the printer while it is ...h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpd07280&... - 75k
Sep 14, 2009 | Computers & Internet
My printer makes a loud banging noise when trying to print.
We solved the problem by buying a new printer. We figured for the cost of service, it was more economical to replace our older printer. Sad that these printers go to waste. Thanks
Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cartridge banging on the right & left walls
There is a thin plastic strip that has small lines on it that stretches across the inside of the printer and fits trough the back of the print head. It is not in the slot of the print head or missing. I fixed my banging Dell 810 printer by putting it back in. I had no idea what it was at first. That's all I can tell ya.
Feb 03, 2009 | Dell 810 All-In-One InkJet Printer
A loud banging noise from inside - as it adjusts post printing
I'd check that there's nothing that's fallen into the rear paper feed that is now causing the rollers to jam and release with the bang you mention.
If you're feeling brave I'd try holding the printer upside down (get a friend to help you and watch out for the scanner sliding out!) and give it a bit of a shake to see if anything drops out.
Jan 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
When you start printing it starts making loud banging noises
It's called an ENCODER STRIP you will have to revmove the covers to reinstall.
Jan 02, 2009 | Dell 924 All-in-One InkJet Printer
Samsung SCX-4216F - loud banging noise
the doctor blade in the cartridge tobe replaced.
Jun 18, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Hp Deskjet D2360
my pc cannot recognize the printer
May 14, 2008 | HP Deskjet D2360 InkJet Printer
Epson r300 banging noise when switched on
you need to reset your printer. you can pick up a utility called ssc utility. and then reset it
Dec 13, 2007 | Epson Stylus Photo R300 InkJet Printer
Brother HL 5250DN Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
