Question about Panasonic KX TS108W Corded Phone (KX-TS108W)
Dial lock Someone put the dial lock on; how do I remove it? I can't dial any numbers.
  • sa_dass Sep 09, 2008
    Hi in my panasonic phone get locked please advise how to remove
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    How do I reprogram a speed dial number on a DKT2010-H that has no display?
    With a DKT 2xx0, you're probably on a DK-XX system
    Try these steps
    Leave phone on hook
    Press REDIAL
    Press SPEED DIAL
    Enter Speed Dial Bin Number:
    (Small system is 10-49 personal, 60-99 system-wide)
    (Medium system is 10-49 personal, 600 - 699 system-wide)
    (Large system is 100-139 personal, 200-999 system-wide)
    Enter phone number
    Press REDIAL to lock in number
    If you're on a CiX system:
    Press #9876
    Press SPEED DIAL
    Press Bin Number 100-199
    Enter phone number
    Press Speed Dial
    Lift handset to lock in
    Oct 06, 2014 | Toshiba DKT-2010 Corded Phone
    What is password
    Hopefully you're asking about the Panasonic Obria dial lock which is a common issue with these phones hope this helps:
    1) Put batteries in your phone and place the receiver on-hook.
    2) Press Function and then the Down direction button until you see "Change Password".
    3) Enter the digits 726276642 (usually it accepts a 4 digit number, but enter this number anyway) and press Enter. This is the Master unlock code.
    4) Now enter your New password, enter 0000 and press Enter again.
    5) Press Exit button (Function button is same as the Exit button)
    6) Press Dial Lock and then press 0000, press Enter.
    May 05, 2014 | Panasonic Lands Phones
    Dial lock
    This worked on my KX-TG3611BX and might work on yours:
    Turn the dial lock off using the following method:
    1 {MENU} --> {#} -> {2} -> {5} -> {1}
    2 Press {*} -> {7} -> {0} -> {0} -> {0} 3 {Save} -> {Yes} -> {OFF}
    Aug 27, 2011 | Panasonic GigaRange KX-TG2432 Cordless...
    Hai Now my telephone dialfacilities locked So please help me how to open .Model No-KX-TG2361JXB[PANASONIC] .Now I cannot dial .Actualy somebody put wrong pin number.I can receive call.
    ok
    you need to enter the right pin number so contact the customer service from other phone...and ask then if u still dont get the pin then tak your phone to a mobile repair shop they will open the phone.
    Jun 15, 2009 | Lands Phones
    Unlocking onetel cordless
    I accidently locked mine, without the help of a baby! (I notice though that you posted this last year, so hopefully it's sorted now). If you press and hold the # key that should do it.
    Apr 11, 2009 | Lands Phones
    Programming Auto Dial Number
    Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
    Number changed :-)
    You can keep putting in a whole boatload of new numbers with this procedure.
    Carl
    Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
    Dial lock
    try this out guyz..
    type 726276642 in the password option and press OK
    VOILA !!!
    Works !!]
    Krishna
    Jan 06, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
    The Phone has been dial locked and I cannot unlock it
    Hello
    I had the keypadlock problem, and i just pressed OK button (first row, second column key) for around 5 seconds and it unlocked itself.
    Feb 26, 2007 | Panasonic GigaRange KX-TG2432 Cordless...
    Panasonic KX TS108W Corded Phone (KX-TS108W) Logo
    59 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
