Question about Roper RT21AKXKQ Top Freezer Refrigerator
Waterleaking from freezerinto bottom of fridge
  • 86 Answers
First check your door and make sure it's closed all the way. Next check the door gasket for rips. What happens is that the moisture in the air is getting in to your frige and condensing on the evaporator coil.
The water then goes down a drain hose to a re-evap pan. Your pan is filling up too fast. Or maybe some one is holding the door open too long. Best of luck!
Posted on Aug 23, 2010
ESL63010 Electolux - Dishwasher keeps beeping in a cycle of 3 beeps and 3 flashes of the 'end' light (flood warning). Waterleaks from the waste connection to D/W. How do I change the hose? Thanks.
You have inlet hose and drain hose so it is possible to water leakage on both. The easiest access to both hose is from bottom of dishwasher.
  • Remove the bottom panel
  • Remove the inner filters
  • Remove any residual water from the sump by
    suction, so that it does not flow into the tub and the
    pressure switch tubes, then lay the appliance on its
  • Unscrew and remove the regulation screw from the
    rear foot (built-in versions only).
  • Remove the screws which secure the bottom panel
    to the base (three screws)
  • Release the built-in retaining elements placed on
    the right and rear side: and remove the bottom
    panel by sliding to the right.
  • You are able now to access any bottom parts
Dado
Oct 06, 2015 | Dishwashers
Showing error code E4
check for waterleaks filling the overflow tray at the bottom of dish washer that is activating the float switch. check for defects or damage at bottom of dishwasher.
Feb 01, 2012 | Bush Dishwashers
2005 TAURUS WATERLEAK
I have a 2004, I dont have a clue what kind of water leak you have but If I had to guess its in the passenger side floorboard which is more than likely the heater core
Aug 23, 2011 | Ford Taurus Cars & Trucks
We have a GC2227DEDB fridge freezer it has a waterleak any ideas
geohgh -- GC2227DEDB Kuppersbusch/Maytag Refrigerator/Freezer - If in high humidity area then water condenses between the outer skin and inner skin. Builds up and then releases once surface tension limit is reached. Releases about 250ml to 500ml or more in some cases, directly onto the floor. Solution is to make or have made a Stainless steel tray to fit under the refrigerator. Motor heat then evaporates the water.
Sep 07, 2010 | Kuppersbusch K EGS 304.0 J Stainless...
Dirty water leaking
sound like the drain pipe that lets water go down to the compresor heater is blocked,,,it need to be cleared out yucky job
Jun 24, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Floorboard on drivers side and backseat floorboard on drivers side soaking wet
You have a waterleak.
Possible locations.
Missing grommet on the bottom floor pan holes.
Door weatherstrip is not sealing door surfuace.
If you have a sunroof. the drain hoses from the sun roof down the pillar is nor connected properly. Do you see any watermarks on the head liner?
Jun 23, 2010 | 2001 Mitsubishi Galant
DU1000CGQ1- waterleaking from bottom of door-could it be the seal that the door seals against?
This could be the problem. inspect the gasket to make sure it is not compromised, holes, breaks. Also make sure that nothing is keep the gasket from making a tight seal.
May 16, 2010 | Dishwashers
Waterleaking on food
you have a defrost and or a drain problem get to the back of the freezer take the panel off and let me know what you see... whirlpoolpartssurplus.com mark
Jun 26, 2009 | Frigidaire FRT17G4B Top Freezer...
Waterleak
Water pump needs to be replaced. water is most likely cumming from seal behind water pump drive pulley. also check hoses and thermostat housing gasket if water pump does not seem to be the source
Jan 08, 2009 | 1996 Chevrolet C1500
AEG dishwasher 80850 code i30 reset
empty it, tip it on its back, mop up the spilt water, reload it and all should be ok. it is a recurring fault on our machine very irritating
Jul 14, 2008 | AEG 24 in. Favorit 40850 Free-standing...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
43 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
