Question about Maytag PYE2300AY Electric Dryer
Maytag dryer thermostat
How do I get to and change the thermostat on the maytag pye2300ay dryer?
My Maytag Peforma dryer works but it seems to not get as hot now and takes longer to dry the same amount of cloths. ?? I have always had an element just stop. Has anyone had an element go slowly bad?
Posted on Oct 01, 2008
    Scholar:
  • 116 Answers
Not 100% about this model, but the stat is located next to the fan.
Remove the front cover - insert a flat blade between the lid and front panel approx 4" in from each side to release the clips, lift the lid, remove the front panel (2 screws) fan and stat at the bottom, rest is straight forward.
Posted on Jun 01, 2008
Dryer stopped running altogether while drying an oversized load of beach towels. Problem is not in the power supply outlet or circuit breaker or the dryer door switch. From another website I learned that...
Go to www.repairclinic.com and enter PYE2300AY. With luck, you will be presented with a list of common repair parts and may be able to view a generic Maytag video showing disassembly and repair.
May 18, 2017 | Maytag PYE2300AY Electric Dryer
I replaced my thermal fuse on my pye2300ayw dryer now it gets to HOT
Whenever you change the thermal fuse the thermostat should also be changed...
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Maytag PYE2300AY Electric Dryer
How can you test the safety thermostat? Maytag Dryer. The safety fuse was blown, very little lint in heating area, so no clog of airflow. So how do I check the thermostat is working correctly?
safty fuse may just be a bad one . to ck thermo use a tempt tester in the vent . it chould cycle at 155 deg on hi and 140 on del .settings. if flex venting is used it may have been kinked . if yo don't tust the thermo the you should change it .. but keep in mind it takes 190deg + tempt to blow the saftey..
Dec 23, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer wont spin
It is fairly simple,but I have changed a few.you may want to pay someone for first change and watch how he pulls everything apart.to replace a belt is not expensive.I charge anywhere from $98 to $115.00.everyone has diferent prices
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
My maytag dryer heater will not turn on or get hot
Check the breaker first, then the connections, then last the element. It should be burned in two if it is not working. If all that is o.k. then the thermostat should be looked at. Have someone ohm it out and check it for voltage.
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Tstat wiring
I believe that this part is a thermostat. If im not mistaken, it shouldnt matter which wire goes on which prong. Think this is a reversable thermostat. It should have just 2 prongs correct? Jim
Aug 31, 2006 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
178 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
