Question about Maytag Dryers
Maytag stackable dryer will not run. When the start button was pressed, there was a sound of the motor trying to turn, but there was not turning. When pressed repeatedly, there is a burnt smell
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
A buzz sound when pushing start
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 17, 2012 | Maytag Dryers
I have a Maytag LDE9304ACM dryer. It suddently quit today. When I press the start button, the start button light "lights up", but there is not sound and no rotation. I can hear the timer. I...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 04, 2011 | Maytag Dryers
My Maytag DE410 dryer is not working. When I press the start button there is a buzzing sound, however, the drum does not move and the start button does not stay depressed.
heatman101
Aug 11, 2011 | Dryers
My son has a Maytag stackable washer and dryer. The dryer will not tumble. Could it be a belt and if so how hard is it to fix yourself?
heatman101
Aug 07, 2011 | Maytag Dryers
Every so often my dryer will not start when you press the button you can hear the timer engage but the drum does not turn and the motor makes a sound like a car that wont turn over. I unplug it and let it...
Dryer Repair - The
Dryer Repair - The
heatman101
Oct 21, 2010 | Maytag MDE2600 Electric Dryer
Maytag Dryer LDE5914 Buzzes when you press the start button but won't turn. Diagnosis? Does it need a motor?
heatman101
Aug 11, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag stackable dryer, start button just makes a humming sound but dryer will not start john s
either you have abad motor assy, or somethinghas gotten dowenin the blower wheel preventingfree spin of the blower threfore holding back the motor from starting
Mar 07, 2009 | Maytag Dryers
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
