Question about KitchenAid KUDR01TJ Dishwasher
Dishwasher not cleaning. Dishwasher turns on, fills and then hums. If we hit cancel, it drains fine. No water sprays around inside.
  • KitchenAid Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Remove the panel at the base of unit below door you should find the tech sheet which will tell you how to place unit into diagnostic, on the spray arms make sure the small holes are clean below the lower spray arm is a screen make sure it is clean not covered or cake with calcium build up if it clogged water cannot pass thru to enter the wash pump you can also remove the screws to take the upper halve apart to inspect the wash pump for any obstruction it is possible you could have a bad motor control or both you didn't mention after the unit fills do you hear the wash pump hum or click
Feb 07, 2014 | KitchenAid 24 in. KUDK02CRBS Stainless...
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
KUD 101 JBL0 kitchenaid dishwasher fills with water then just hums. When I hit the cancel/drain button the water does drain.
Before you go ordering any new parts, have you made sure that the dishwasher is LEVEL. Surprisingly this is a very finicky thing with dishwashers and I even went as far as replacing my float switch before realizing that the dishwasher was slightly out of level. Once I straightened it out the dishwasher was totally fine. Just to be sure, I skewed it in another direction and had the same problem. Like I said, give it a try (front to back AND side to side) and you might be in luck!
Jan 04, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishwasher fills with water but then hums. Water will drain if cancel button is pushed.
Sounds like something stuck in spray impeller. Remove spray arm and top of motor pump assembly and clean.
Oct 27, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Fdb126rbs2 fills and drains fine but does not
DO YOU HEAR THE MOTOR START OR HUM AFTER THE WATER FILLS? IF IT RUNS CLEAN YOUR FILTER AROUND THE BOTTOM OF THE LOWER SPRAY ARM INSIDE. LET ME KNOW IF YOU HAVE MORE INFO.
Apr 25, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Quiet Series 100
It sound like a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if pump spins when it should force the water up into the sprayer arms. In case it doesn't spin you should replace the pump. Good luck !
Sep 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
KitchenAid KUDR01TJ Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
