The display on a Toshiba P305D-S8834 laptop is very dim. I bought a LCD inverter and replaced it but the problem is same. When I connect that laptop to an external lcd then display came fine on it. So, will it means that laptop's lcd screen is damaged. Please note that there are no white or black dots on the lcd.
  • Faheem Ahmed Aug 27, 2010
    I bought a new LCD screen just to avoid changing backlights because I was afraid that may be LCD will damage and according to instructions which you sent me shows that CCFL backlights are in the LCD Screen so by changing an entirely new LCD should solve the problem but after even changing the whole LCD, I have seen the problem is same i.e., DIM display. Now, please note that inverter and LCD screen has been changed. Now, what should I do ? Please advise.
  • Computers & ... Master
  • 5,103 Answers
Actually it may not be the LCD screen but the backlights. These are sandwiched against the screen on the sides of the LCD panel.. You need to order by length and width and get ones for your screen size. Separate the screen from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
See http://lcdparts.net/CCFL3D.aspx for backlights for specific brands and sizes of laptops.
BTW: you can check if the new inverter is working with a multimeter. If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
I hope this helps.
Posted on Aug 23, 2010
  • 3 more comments
  • Cindy Wells Aug 27, 2010
    Can you attach an external monitor to the laptop? (Some will toggle an external monitor on with + + (press all three simultaneously) when the VGA port is active.) This will check if the problem is with the on-board video or with a part of the monitor hardware (ribbon cables, backlight and inverter). Cables can easily come loose or be damaged during the reassembly. Make sure they are all properly seated: http://www.laptoprepair101.com/laptop/20... . Another thing to check is the laptop lid switch that should put the computer into standby when the lid is down. If that is sticky you might get false shutdown issues.
    Did you buy a new screen or a used one? What vendor did you receive it
    from? Did they provide a warranty? Sight unseen, I can't tell if the
    replacement had a good or bad backlight. There are testers available at
    lcdparts.net. A similar issue exists with the inverter - is the
    replacement working? (an oscilliscope with probes held about an 1" above
    the board and a fraction of on inch apart works as well as the testers
    for diagnosing the inverter.) A free-standing backlight can check the
    inverter if it is a known good part.
    The backlight isn't really in the screen. The screen has many layers - glass, LCD sheet, other parts. The backlight gets crowded into the edge between the layers. See this for a different set of pictures: http://www.laptoprepair101.com/laptop/20... .
    Dear Cindy,
    Please note that when I attach an external monitor then image came normal on it. On this Toshiba laptop, it requires "Fn F5" key combinations to switch monitors and the image is normal on external monitor but again dim on LCD of laptop and both new and old LCD screens have same result and new and old LCD inverters also have same results. I even tried to increase the brightness but it was also not working. As I told you the purpose of getting new LCD screen was that I don't want to play with CCFL Lamps and as per my understanding, with new LCD, the CCFL lamps will also be fine and also please note that both items are new (not original Toshiba but their OEM compatible).
    So, now I am a bit confused what to do ? What thing could be wrong.
    Thank you in advance for your help and co-operation.
    I wasn't sure if you still had the external monitor on the laptop. That's why I asked.
    When you ordered the new inverter, did you match the Rev number for the part? I've seen a few mismatched inverters that had the contrast control reversed. You can try lowering the contrast and seeing if that brightens the laptop screen (while the external monitor dims).
    Since all the parts are new, I'm not sure what is wrong. You could have either a bad cable or one of the new parts from the OEM manufacturer are faulty.
    Additional testing is probably needed. This is probably time to invest in a lcd tester. oscilliscope/mulitmeter (only tests the inverter) or at least a spare backlight and inverter. Use the spares to test the LCD screen and inverter without the laptop being reassemble. Alternatively, a visit to a shop with an lcd tester. (I've found online shops that specialize in lcd screen repairs but I'm not sure how close they are to you.http://www.moniserv.com/doc/inverterrepa... orhttp://www.lcdrepair.us/ )
  • Faheem Ahmed Aug 29, 2010
    Dear Cindy,
    I don't have anyone nearby in Baltimore who have LCD tester but I experimented something which I want to discuss with you.
    As I told you I have now one new LCD screen and one new inverter. First I tried new LCD screen with old inverter and then new inverter but the result is same i.e., dim or too dark display. Meanwhile I attached external monitor and it was fine. Then I again attached the old screen but forgot to attach any inverter and put the laptop on and found that the screen is still displaying in a dim mode then I tried new screen without inverter and got the same result.
    Now, my question is it possible to get display without LCD inverter and also will it means that problem is only in the inverter and both LCD's are fine.
    Please advise me with your precious comments.
    Thanks
  • Cindy Wells Aug 29, 2010
    Unfortunately, that test (running the laptop screen without the inverter) can only tell you if the video signal reaches the screen and if the LCD pixels are active. (Even that could be difficult to resolve since most can't see a lit pixel without the added light behind it from the backlight.) It won't tell you anything about the backlight or the inverter. The backlight and inverter are paired; they are the equivalent of a full-length fluorescent tube and the ballast of a fluorescent light fixture. The backlight is driven by the inverter and can't light without it unless you put it near another source. (There is an old physics demo for lighting a fluorescent tube without the ballast - get the pins near another current source.)
    A multimeter that can measure high frequency (or an oscilloscope) would be a much better way of testing if either inverter is working. Similarly a backlight that you aren't going to install can test the inverter if you know it is a good backlight. Then you can assume it's a bad backlight if the inverter passes the test (whether it be the lighting the spare backlight or producing the high voltage with phase change). The lcd testers are just convenient tools for those who do a number of the tests since it can check the backlight or the inverter separately and is faster than the multimeter test. (There are some who try to test the inverter board with a multimeter but because of the high voltage the hover test is safer.)
    Fluke sells a multimeter which can handle the frequency of modern laptop inverters. (Oscilloscopes can be found in many academic laps in the engineering or physics department. You can ask at a local high school about borrowing one (or bringing your parts to the school for an afterschool demo and test). I happen to have access to the oscilloscope at home so I only have the basic multimeter.)
    There is a way to get the screen lit without the inverter and backlight combination. Take an old CRT monitor, take it apart and replace the guts with a light bulb and place the LCD screen in front of the bulb. http://www.ccs.neu.edu/home/bchafy/monit... has the details on this hybrid. However, that is only really useful for fixing a broken external monitor and not a laptop screen.
Screen is black. Power button lights up, fans and DVD seem to work.
hi there,
What you are experiencing with your laptop is "POST" (Power-on self test) issue. Here are some steps which you can try.
- Remove the battery and ac adapter (as well as external peripherals attached), press the power button for atleast 15 seconds, try to power on your computer again.
- If you have external monitor, hook it up. Display on the external monitor would mean that you have a LCD issue (check LCD cable, LCD inverter and LCD backlight in this case). No display on the external monitor would mean that you need to replace the video card (if dedicated) or replace the whole system board (if integrated).
- Try to reseat or replace the memory module as well, it might help.
Regards.
May 10, 2011 | Toshiba Satellite P305D-S8834 17 in Laptop...
My Toshiba satellite P305D-S8834 will not turn on. It was not dropped. I opened our lab top and it would not turn on. I push the power button and lights come on with the power switched an indicator lights....
More an likely its your LCD. If it powers up and you are getting a hard drive activity light then that points to your LCD, could be a damaged backlight or inverter.
Apr 11, 2011 | Computers & Internet
Can I install a better CPU into my Toshiba Satellite P305D-S8834 17 1 Widescreen Notebook Computer then the AMD Turion X2 Processor RM-70 it came with?
Changing CPU is a serious change. When your unit was built the processor speed and type were written into the BIOS. When we change the CPU to a different type there is a chance that the BIOS will not recognize it and refuse to boot up. Also Windows was installed with the original CPU and a major change in hardware could mess up Windows.
I did some research and found this model comes with a 2.0-GHz AMD Turion X2 Dual-Core RM-70 CPU and 4GB of RAM. This is not the fastest CPU that can be put in a laptop but a very good one. (faster than mine)
I can guide you through the steps to replace it but my advice is stick with what you have until it breaks and buy a faster laptop. The upgrade won't gain you enough to justify the expense.
May 21, 2010 | Toshiba Satellite P305D-S8834 Notebook
I just installed vistas ultimate on the satellite p305d-s8834 and now I cannot detect any network devices/hardware. The laptop did not come with any recovery discs. can I download the device or is there...
Hi, lets restore your ("systems configuration"), by doing the following: From the Start Menu, Type: Toshiba, in the "search box." Next find the Toshiba Application Installer, if your computer have this "Function?" it would make the process alot easier; open the (TAI), and click next, you can select from different Drivers to Install, click to (highlight), click on the install button. "It is hightly recommend to restart the computer, when finished!" "Did this solution help?"
Jan 30, 2010 | Toshiba Satellite P305D-S8834 Notebook
My drivers don t launch evry restart
Kindli go on This link
toshiba driver site
https://www.toshiba-india.com/DriversDetails.aspx
Give your notebook modul No And download your driver (its free)
Nov 19, 2009 | Toshiba Satellite P305D-S8834 17 in Laptop...
When I turn my Toshiba laptop on,it's black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 26, 2009 | Toshiba Computers & Internet
Hi, I have a P305D-S8834, daughter left it on the bed on and when we came back it would no longer boot up, only lights on the base, nothing on lcd, I replaced the motherboard and still the same. Any ideas?
Probably burned struff up ... on the bed the computer cannot get vital cooling air because the covers blocked the fan suction.
If this is the case, you have a parts computer. Dont try to fix it.
Oct 07, 2009 | Toshiba Satellite P305D-S8834 17 in Laptop...
Dim display ... no backlight
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 30, 2009 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
Toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 25, 2009 | Toshiba Tecra S1 Notebook
Computers & Internet Logo
David Payne
David Payne
