Question about Roper RAB2121KW Top Load Washer
Washer will not fill with water
My washer will not fill with water, the water will run until I stop it. This does not happen every time, but increasingly more.
  • Toby Norton
    Toby Norton May 11, 2010
    How do you "stop it"? Do you turn off the vavle at the wall or do you just turn off the michine with the timer knob?
  • 246 Answers
We have not heard back on this in a about a week. I'm presuming it's been repaired?
Posted on Jun 21, 2008
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
I have a LAT9306AAE washer that wont stop filling with water and overflows with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} If it fills with water and starts the cycle and the water keeps running in and the water won't stop when you unplug the washer then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Dec 29, 2009 | Maytag Washing Machines
Top load washer won't stop filling with water
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
or
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Nov 08, 2009 | Amana NTW5100TQ Top Load Washer
I have a kenmore washer and when i set and start it the water runs in and won't stop running.
If it doesn't start the cycle:
Nov 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills with cold water but does not stop filling
OR
Sep 15, 2009 | Maytag LSE7806A Top Load Stacked...
G e washer WBSE3120
Sep 14, 2009 | Washing Machines
Water will not shut off
If the washer fills and don't start the wash cycle...
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It need replacing.
Sep 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine won't stop filling
Hello Marty, there are only two possible reasons for your trouble.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Aug 19, 2009 | Neff W4380X1 Front Load Washer
Washer over fills with water
There is a pressure switch with a long thin hose or tube attached to it. It is inside the washer and can be located with the back or the top removed. As the water fills, the pressure in the hose increases and the switch activates at a determined pressure, shutting of the water valve. I have seen bad switches and pinched or clogged hoses..
Jan 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills continuously until it has overflown
I found this answer on Repairclinic.com. Hope it helps...
Oct 22, 2007 | GE Hotpoint Super 3.2 cu. ft. Washer
Roper RAB2121KW Top Load Washer Logo
59 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
